Topic: spark plug ??? (Read 1090 times) previous topic - next topic
spark plug ???
hey guys
can someone explain spark plug gapping? the auto parts site i was looking at had the motorcraft at .044 for my 1984 3.8 engine, and then i was looking at the specs on ericscoolcats and it is listed by ford as .054 . does that mean they are the wrong ones on the parts website, or do they have to be regapped?
also are the motorcraft good , or is there better ones . the car has 117,000 miles on it and im not sure if something different should be used on higher mileage cars.
i know when i had my 1995 towncar i tried a different brand of wires and plugs and the car ran like :toilet:  the 4.6 on it was very touchy to that stuff.
thanks for any help
eddie
eddie
my rides well some of them work:hick:
1995 towncar in black 246 K non running
1989 continental 110K waiting for a part
1984 cougar head gaskets done almost ready!
Yikes the daily ride ...1998 chevy lumina:hick:
spark plug ???
for my 84 cougar v6 that's all i used motorcraft spark plugs. since i use to work at a parts store i was able to try every kind of plug for a little bit cheaper then usually and notice that factory type plugs work the best. like for ford use only motorcraft or autolite, chevy used only ac delco and etc.
spark plug ???
The decal on the fan shroud of my 84 3.8 T-Bird says .042-.046
spark plug ???
Setum at .040 and don't worry about it... On std copper plugs that will give you about 7500 miles before they've worn to .042-.044... Wider gaps allow more voltage to build in the coil for a slightly hotter spark, down side is the higher voltage burns up the plug wires... Unless you want to rep plug wires ever 30-40K mi, forget you ever heard of setting a plug at more than .050...
I just replaced the plugs about 10 days ago in the beater '93 Grand Marquis(started skipping on #8), yep they're set at .040...
spark plug ???
thats what i was thinking blackcougar... i like OEM stuff, but ya never know.
interesting info on the plug gaps turbo....  i guess they would like them set higher so you spend more ???
eddie
spark plug ???
Quote from: TurboCoupe50;308221
What he said.  Unless you're running a CD or Digital Ignition Id stick to the manufacturer specs.
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
