Topic: 86 tbird 4x4 (Read 7061 times) previous topic - next topic
86 tbird 4x4
Reply #45
There's no such thing as a '60 Bronco, nor any Bronco until '66 for that matter. If you can find one worth buying, expect to pay more than you can imagine, as they're mighty uncommon, and most of what's left are in the hands of people who won't come off of them easily or cheaply.
Best thing I can think of is to measure your wheelbase, and then goggle or search of your choice and compare wheelbases of vehicles such as reg. cab shortbed rangers, s-10's, and such.
I really doubt you'll find anything that will be a direct "fit" in regards to wheelbase though. There'll most likely be some sort of frame shortening or lengthening for a perfect match.
That's the easy work.
Then you've got to fab (or have someone do it for you) the body mounts and all that that entails.
Sort out the wiring, throttle cable, shifter mechanism, and hoses, etc.
First off, what size tires do you want to run under this...thing?
Anything much over 31's will probably require either a suspension lift, or some sort of body lift.
Nobody makes body lift kits for a Tbird on a ranger frame, so you'll have to make that yourself. Got a welder, and steel stock? ;)
Don't take this the wrong way, in NO way am I trying to put out your fire...but if you're gonna do it, do it right, and do it safely.
And start off with a good, solid plan from the git-go.
If I was you, i'd keep the Tbird you have now, leave it as-is, and find another Tbird or Cougar to do this with. Preferably one that doesn't run, or is missing the driveline. Odds are, all of that will need to be yanked anyway.
On other thing, assume you have a 4x4 Ranger frame, and you "swap" a 5.0 into it.
You'll probably also have to mount the engine/trans/trans-case further back in the frame so the engine will sit in the right location in the Tbird, yet still keep the front wheels/tires in their necessary place.
BTW, there's kits for swapping an efi 5.0 into a Ranger/B2/Explorer....if you want to go the V8 route (still assuming you use a Ranger/B2 frame...)
Do a lot of searching on the subject, see if it's been done...learn everything you can before you start, and a painful lesson I learned I'll share with you right now as far as tools...the...i mean THE first tool you should ever pick up before a project like this is a good ole fire extinguisher.
Trust me when I say they're like shag or air....it ain't important until you need it and don't have it! ;):rollin:
Good luck, and keep us in the loop.
buggmann
Reply #46
as of now i don't think i'm going to do this as of now i just think it is going to be a big pain in the a$$ and i still have to find a car for the wife to drive so i think i'm going to put it on hold for now but i'm still am going to keep looking i might just go with the v8 swap and do some body work on the car and that will be it for now
86 tbird 4x4
Reply #47
Now that sounds like a plan. You should only be considering taking on a major project IF your daily driver situation is fine. It's tough to justify spending any money on a fun project if your wife has to ride the bus. If I tried that, my wife would be throwing me under the bus. lol. Good luck!
1987 Turbo Coupe - Son's car
1934 Ford - My project car
buggmann
Reply #48
ok here we go again on the door glass but i need to know if
a 86 cat door glass w the vent will fit my 86 bird w the vent
i had some one on here pm me and they have a 86 cat w the
same doors as my bird and ask if it would fit i think it will but
not sure does any one know if it will fit
86 tbird 4x4
Reply #49
The Cougar doors should fit fine.  The only thing that might be off is I think Cougars usually had the thin trim on the doors and Tbirds had thick moldings.  Here is a parts inerchange list  http://www.coolcats.net/tech/reference/parts.html
buggmann
Reply #50
hey thanks man that helped out a lot
86 tbird 4x4
Reply #51
The Tbird doors are identical to the Cougar doors. There would be a misaligment and mismatch of trim and moldings if you mix 1983-86 doors with 1987-88 doors. For 1987-88, the door and rear quarter panel glass was made flusher to the surface of the bodysides therfore all the glass mouldings are thinner and different. The door skins were also revised to be smoother where the bodyside moulding is attached.  The perimeter body side moldings and bumper strips were raised slightly so this accounts for moulding misaligments when mixing doors, fenders and front header panels between 83-86 cars and 87-88 cars.
