Topic: 86 tbird 4x4 (Read 7014 times) previous topic - next topic
86 tbird 4x4
are you realted to "quicksilver"??
1979 Ford Fairmont
[/B]
86 tbird 4x4
:rollin:
86 tbird 4x4
if you do it dont coochfoot around(as in cat) make it a V8
buggmann
hell i would love to make my car a v8
as it is even if i dont make it a 4x4
86 tbird 4x4
if i were going to make a 4x4 thundercat, i would use a dana 30 high pinion front end out of a jeep cherokee and swap the rearend out for a sn95 mustang rearend to gain 5 lug and disk brakes on the back.
i would probably remove the front subframe completely and build a new frame section from 2x3 3/16 tubing from the rear subframe to the front bumper. you could run a t5 transmission with the tailhousing and output shaft off a mid 80's jeep cherokee that came with a t5 and use the jeep np207 or np231 transfer case.
as you can tell, i too have put some thought into this....
86 Mustang GT
86 tbird 4x4
Quote from: Dougy_Fresh;307215
I've been in the planning stages of using the driveline from my '95 Jeep ZJ for a retro 4x4 of some sort, myself.
1987 TC
buggmann
i was just going to drop the bird on a 4x4 frame
that way i did not have to build anything see i
was looking at like a s10 or a ranger something
with a v8 strip the bird and then drop the body
on that frame and go from their
86 tbird 4x4
s10's or rangers never came with v8's in them from the factory. and i'm sorry but theres no way you could just slap a t-bird body on a truck frame and it not look like hammered et.
you would have to BUILD it. no way around it
86 Mustang GT
86 tbird 4x4
Drop it on a late 60's to early 70's Bronco. I owned one with a D44 in the front and a 9" in the rear with 4;88 gears and 40" super swampers. That was a fun ride. Very basic truck and very easy wiring on that too. Plus it has a narrow frame and narrow diffs that would fit the bird better.
:burnout:
buggmann
Reply #39
that is what i was thinking just
get a frame and then find a way to drop
the t-bird body down on it
will a 88 bronco work i found about 5 of them cheap
and all of them run
86 tbird 4x4
Reply #40
nothing is going to just "work". it'll take alot of fabrication, wiring, cables, etc. you need to take measurements of width on frames and such. there is no easy way to make it look good.
buggmann
Reply #41
hey just to let you all know i think i found a 1988 ford bronco 2
that i might buy and use to make my 4x4 t-bird the bronco has
a good runing fi v6 with a auto trans not sure about the 4x4 if
it does not have a 4x4 it is a easy fix im going to look at it later
in the week will keep all of ya updated
oh and to let of of you know ahead of time all the parts i take off
the t-bird will be put up on here for sale
86 tbird 4x4
Reply #42
Might want to measure the wheelbase, I'm thinking a Bronco II will be too short.
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
86 tbird 4x4
Reply #43
Quote from: cougarman;307793
IIRC, it's something like 94.5"  I had one that I put a '66 Bronco driveline under.  I wouldn't use the BII. IMO
1987 TC
buggmann
Reply #44
well i have been looking but the 1988 ford bronco 2 i found
is the only thing in my price range i have have look for a bronco
60-70 but the ones i have found well people love them even if
they are junk and have not seen day light in 30 years but im still
looking but what is wrong with the 88 b2 are they that bad
