Topic: Droool - MaxJax. Portable Two Post Lift! (Read 3524 times) previous topic - next topic
I wan't of these soo bad.  I dream of the day I can have a full size lift.  Perhaps this will hold me over.  Drooool.
http://dannmar.com/dannmar-products/two-post-lifts/maxjax.html
I need a thicker garage floor.... and $2500
85 Tbird 5.0
78 F150 351w
13 F150 4x4 3.5 Ecoboost
I turned down a free 2 post lift last spring
:confused: May I ask why?
85 Tbird 5.0
78 F150 351w
Not high enough(yes i know it's for small height rooms).
Try pulling a trans or engine at that height on your knees,ouch.
I agree, way to low for a lift.
I passed up a full height 2 post lift, only because I had nowhere to store it. and I still don't have a bay to put it in, where the posts wouldn't be in the way of moving a car around. Plus they're a pain to get in, and out of a car, so everyday garage parking would be a pain in the butt. the last time I took the vert to my friends garage, I almost couldn't get the door open enough to get out of the car. If I need a lift that bad, I'll take it to a shop.
I thought the same-if you read the specs it says it will go up to 76" inches=6'4".  That should be more than enough room unless youre built like the Jolly green giant.
wonder what my ex cab 01 ford 4x4 weighs? over 6000
hmmm. How can it go up higher then the post height?
the specs sheet
Max Lift Height (Pad only): 45" / 1143 mm.
Max Lift Height (With 3" Adapter): 48" / 1219 mm.
You're right-I was reading the specs for another unit D92X. 45" is def no good.
but I see that for $300 more at a diff web page, you can get a full height lift.
I don't have the ceiling clearance to get to a full height.  Who says you have to go to the top to do work anyhow?  I would probably raise it up a foot or so and work from my creeper for trans work.  Exhausts and oil changes could go all the way up.  I'm just pretty tired of jackstands and jacks.  I'm just dreaming.  Some day I will build a shop with a full height lift.  Thats the dream at least.
I purchased my lift from this company
http://www.asedeals.com/two_post_lifts.html
And I see they have this lift with lots of pictures here, also a little cheaper at $2,172 with free shipping.  But I sure do not like the max lift; but it is better than any jack.
http://www.asedeals.com/two-post-lifts-MaxJax.html
Lots of other lifts listed on the web-site.  They were also nice to deal with and when you call them sometimes they take a little off their listed price.
TED
For lack of overhead clearance, I think the coolest solution is going european/old school. Like my dad did recently in his garage. Instead of lifting the car.. dig a pit to get underneath the car. Him and my brother, and I dug a pit,16 feet long and 5 feet deep and then he poured a 3" concrete wall. covers it with planks of wood when it's not in use. Works like a charm.
He even put up mirrors on the wall and painted the outside yellow so you can see exacty where your wheels are when you're driving up over it:
