Topic: TFI dizzy with carbureted engine (Read 829 times) previous topic - next topic
Does anyone know all of the inputs to the TFI module which would allow timing advances. I plan to run the TFI distributor on a carbureted 5.0 motor(3.8 V6 computer). I'd like the advance to work, but don't have an old distributor to use
While at first this sounds like a good idea, better forget it and get a regular vac/mechanical advance dist... If you don't have most of the inputs(sensors) connected to the ECU, it will go into limp mode(yeah that's a GM term)and timing advance will be locked out...
