Topic: TC to HO fan question (Read 2154 times) previous topic - next topic
Can I use my TC electric fan whith my HO swap planning on a stand alone temp relay to trigger the fans I guess my question is will the TC fans move enough air for the HO or are there any clearance issues with the TC fan shroud & fans with the HO
87 TC
the TC fans wont fit, I was gonna try something like that with my 5.0 TC project but I'm pretty sure there is going to be a clearance issue with the fans and the waterpump.
Yep. there is. I used a mark 8 fan......or you can use a Taurus/Sable fan with a DC controller
:burnout:
I'm using a Taurus fan on the Sport.When it hit a high of 117 degrees last summer,the car stayed cool.The fan may be a little too good.The Taurus fans are what I would lean towards because they are easier to find from the boneyards,and IF mine ever fails,there are always a lot of Taurus's in the yards I go to for an easy replacement fan,or fan motor.
Vinnie makes a good point. A mark 8 fan is hard to find. I had a 74 Bronco off road truck with 8" lift and 40" Irok mudders. My fan failed after a big bog swallowed my truck. Once I got out the fan ran for a few min and died. I went to the local yard and found 15 taurus fans sitting there. No mark 8 fans were to be found. Now I am thinking of doing a taurus fan now.
:burnout:
There's always taurus's in the yard, They must of sold a shiznit load of them.
99-04 Mustang GT fans will work too.  I swapped one into my F150 and have had no problems.
i use the ford taurus dual fan setup with lincoln continental fan motors. it works so good that it feels like they blow like a tornado.
