Topic: dying interior panels? (Read 2665 times) previous topic - next topic
Has anybody had any luck with this? i recieved a couple blue door panels from Jerry (thanks again). Now i need to make them medium canyon red. Does anybody know what products to use?
I'm kind of at a loss. I called the local upholstry guy and he said his dyes would bleed threw..
thanks,
Chris
When I redid the headliner in the Scorpio, I also dyed some of the grey parts black.  I used the SEM stuff and it worked great.
Clean the parts, use the proper prep/primer for what you're dyeing, and it will turn out fine.
You can find the SEM stuff online, or even @ Eastwood.
thats what the upholstry guy told me, I'm gonna try that route, i was just worried about going from a dark blue to a medium canyon red. as for the carpet on the door panel, im not sure what im going to do yet.
I bought some red vinyl interior paint that covered black pretty good. Took about 3-4 coats, but covered it all. the panel on my vert (Drivers side) was dyed. you can see a faint trace of gray showing through on a section of the carpeted section. (probably worn off from shoes rubbing on it down there. It might have been SEM. I'll see if i can find the can, but the color was a bit to dark for my 87's interior.
thanks jerry and chuck, when i get some funds ill start doing a write up with my luck on dying :)
Chris
Or you could just ditch the porno red interior and go with basically any other color. :D
1987 Turbo Coupe - Son's car
1934 Ford - My project car
i love the porno red tho. haha
I figured that, I was just picking on you. My wife has red interior in her Mustang and loves it!
porno red is the only way to go. my garage is like a porn movie set, with all the red I have in there.
Quote from: daminc;305360
Right, that's the ONLY reason...  ;)
anybody know if 84 mustang red is the same? they have it for 12 bucks a can at latemodelrestoration.com. otherwise id have to spend 98 dollars a quart at carquest.... and i DONT want to do that haha.
thats what  i thought. but i wasnt sure.  so cool. i can save alot of money and time. thanks eric.
hey guys! finally got my paint to do this!
Just wondering, what i got to do to get this going.
I know i gotta clean the panels with acetone.
i have a can of vinyl prep. the color i need. and a can of adhesion promoter.
Not sure if i need the adhesion promoter. but i figured i'd pick it up just in case.
anyone got a process of doing this?
tried searchin, couldn't find much.
Thanks,
Chris
decided to man up and figure it out myself haha. wiped the panels down with acetone, (as told by a local interior guy.) then used the vinyl prep/ cleaner and med. canyon red. from latemodelresto. i like the results. not perfect. but good enough for me. especially knowing that i did them myself.
The carpet im going to be painting black to match the other black accents in my car.
