Topic: 86 capri K member in an 87 bird (Read 1314 times) previous topic - next topic
OK i know that I will have to lengthen the rear mounting holse in the stang kmember and I will also have to make a spacer for front mount on the stang kmember. My question is can I take the whole K-member and suspension and swap them from the stang to the bird or will I have to swap the a arms and spindles. In a nut shell can I simply just pull the stang k-member with everything attached spindles and all and put it in my bird.
87 TC
yes, but the track width will be a little narrower. something like 3/4" per side. the struts will be approx 1" too short also. (if using the Capri ones)
1979 Ford Fairmont
[/B]
ok so every thing but the struts would be a good swap I can live with the track width being a little narrower what struts would I have to go with my PRC's are shot and would be planning on putting new springs and struts in while im doing the swap
87 TC
94-04 mustang if you have the spindles for 11" rotors.
1979 Ford Fairmont
[/B]
