Topic: k member interchangabity (Read 2392 times) previous topic - next topic
i have 1986 cougar and wondering if a 1988 mustang k member will fit?  i have access to one in mint condition.    wondering if i should take it.  just to have around in case i ever need it down the road.
If it's free,why not?I haven't ever seen a K-Member go bad before,though.It will bolt on,but I'm unsure if you'd need to swap lower a-frames or not.Some of the Stang parts were the same as the Birds and Cougars for a while,then they changed it all up.
Not a direct swap.  Search around...it's been discussed umpteen times...
I thought that the K-Member was a bolt on.Well,I'm glad I'm keeping my '88 k-member under my '88 Bird.No worries with swapping.
not one k memeber has ever been  a direct swap from a pony.
I really did think that the Fox Stang crossmember would swap over.I may have been thinking about the different Fox Bird/Cougar k-members.At any rate,I was mistaken,and need to be confined to my house for a week with pay pending an investigation over my misleading information.My apologies are given in the meantime.
Quote from: vinnietbird;304416
Aren't you confined anyway due to snow?
I don't know for fact but within the mid size foxes all will interchange but I'm not sure about the 87-88 k members.  I've heard they are diffenent.  The Mustang Ks are different in that a couple of the bolt holes will not align without rounding out the holes.  Plus I think the track is narrower which would require not using the Mustang contol arms on the bigger fox.  Other that that I'm totally ignorant on the matter.
This I do know.  There are basically two k members.
1 for 2.3, V6 and V8 and 1 for the I6.
Armed Forces Car Club
Eastern Sierra Chapter, California
WEB:  armedforcescarclub.com
The snow here is mostly gone.I am going to watch a movie and feel bad about what I've done.LOL.
The Tbird K-members are NOT the same as the Mustang ones...
There are minor differences in the mounting, which can be overcome if needed.
Motor mounts are totally different on the 86-88 TBird K-members.
ETC
ETC
Things that have been covered here quite a bit...
I'm good with that.I have learned something new today.
i was thinking that since fox mustang front control arms will work with a pre-1987 fox cougar / tbird,  that the k member might also work.    No point in me taking it if it isn't direct bolt in.    if i wanted a Kmember that required extra work to install i'd get this one:
http://www.ajeracing.com/mustang.php#%3CNo%20anchors%20found%3E
I would like one of those,but I have bigger needs right now.
where is this k member? im in jersey too and if it's free i might take it until i get a different one
it is a friend of a friend in the poconos who took apart his mustang to part out and has left the shell and k member.  PM me with your email or phone.    realize-  i'm not sure if he was looking to give it away in general.  or looking to sell it..... but offered to me cause my friend and I helped him fix his boiler (and he knows i am working on a fox body).    i will poke around and see what the deal is.  in any event, worst case,  i'm sure it's not too much $$  and i know it has no rust.
