Topic: Needing parts for 5.0 HO Swap (Read 1214 times) previous topic - next topic
I would like to find a tbird or cougar 5.0 wiring harness and would also like to buy motor mounts from a 5.0 bird or cougar
87 TC
I've heard that the '88 5.0 Thunderbird/Cougar is the harness to have.Motor mounts are getting hard to find.I need to start grabbing them at the yards when I see them.
What year 5.0 harness you need?  I have an 87 one if that will work for you.
Not to sound like a dick but can't you still get new motor mounts at Vato Zone or Advance???
Either way doing a K-member swap to the 84 V8 style (think stang mounts is the way to go).
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
You can get the cushions for the mounts,but the actual brackets that bolt to the car are not available.....unless you find them from an individual or a salvage yard.
What year is this car getting the swap?
Quote from: vinnietbird;304123
Ahhh thanks for the clarity.
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
I'll have a brand new set of cushions for sale after my engine swap....whenever that will be.maybe sooner if I can get my mounts swapped out soon.I need a decent temp outside to do so.
The swap is going into an 87 TC
87 TC
Oh ya I would also need the fuel lines from the filter to the motor. Do I have to use a 5.0 bird drive shaft or will my 2.3 t5 shaft work? How much difference would there be if I used the k member out of the car I am getting the motor out of (86 mustang capri)
87 TC
OK update to what I am still needing
Fuel lines from a 5.0L bird from the fuel filter up to the fuel rails
throttle/cruise cable
would like a 255 fule pump if anyone has one laying around
9al massair computer
mass air conversion harness
87 TC
Got a 9ap, the harness I can make for you.
Quote from: bigbada1;305217
throttle/cruise cable might have
would like a 255 fule pump if anyone has one laying around have a drop in assembly with 255
9al massair computer have one
I will send you a pm.
I have a cruise cable...look at my "for sale" stuff in the For sale section.
The throttle and cruise cable are two seperate cables, right?
