Topic: winter ressurection ver2.3 (Read 8825 times) previous topic - next topic
Reply #45
That's almost exactly what I wanted to do, but south of the Red River the pipe has to exit after the rear axle.  Shape it like a flat oval, that will be sweet.
BTW, love those wheels.
__________________
Twin '85 TCs
White/ Grey 2-tone
Reply #46
Quote from: t3skidoo;312970
Nice tires, too.
1979 Ford Fairmont
[/B]
Reply #47
buttoned up a few things, and fired the car up this afternoon. i really wanted to hear the new exhaust before i pull things back apart to swap the clutch.
go easy on me, i just figured out my wife's ipod can shoot video w/sound and this is the first thing i decided to do with that knowledge! :hick:
Reply #48
Pants=tight.
Reply #49
well, i guess this explains the clutch slippage that started last summer
just ordered a new 4puck disc from clutchnet, and a pressure plate from pyropete. picked up an escort flywheel yesterday.
Reply #50
NEW PARTS!!
also added some fresh ujoints and an AOD slip yoke to my aluminum d/s. for whatever reason, ford put smaller ujoints in 5.0 cars than in the turbo cars. i had to use a 1310 to 1330 conversion joint on the front.... i guess if i find a 1330 AOD slip yoke down the line someplace, i will swap it out later, but this one was free.
hopefully ill get my flywheel back from the machine shop tomorrow. i had them redrill the escort flywheel for the larger TC pressure plate. i thought about doing it myself, but they have a fancy CNC mill vs. my access to a manual mill, plus i dont have a rotary table at work. i figured a couple hours of my time is worth about what they charge me to do it up in about 15mins and just be done with it....
Reply #51
Quote from: Tbird232ci;313373
Pants=tight.
:rollin:
Reply #52
mmmmmm tires swapped over onto the new wheels.
and here is what ½" difference in rim width can do to tire fitment. on the old 8" wheels my sidewalls were perfectly square
7.5" fronts
8.5" rears
Reply #53
oh to hell with updates anyhow.......its alive again, finally.
took forever to get my flywheel back, got it installed, fiddled with the pivot ball stud a lil bit.
installed trans and went to install the d/s. found out the yoke i got from a buddie was twisted and wouldnt let the d/s go forward far enough to connect to the diff.
pulled the diff  to replace a noisy pinion bearing, and found out it was way worse than i thought. ended up pulling the diff and replacing all the bearings.
got a different slip yoke from the junkyard, and reinstalled the new aluminum d/s again.
finished up the hangers for the exhaust and slash cut the tip.
buttoned up a few other things today, and pulled it out into the driveway. havent gone for a ride as yet, still need to get some gear oil....
got a list of lil things that need attention this summer:
install my wide band o2
reinstall my gauge panels
modify and install a solid steering shaft i picked up
build new mounts for my e-fan
install some 46lb injectors i have here and see if i can make any more power before i commit to head work and a tuner
etc etc etc, i wont even get into my plans for next year....this thing is never completely finished. :hick:
Reply #54
Those wheels and that stance is just pure awesome.
Reply #56
Yay!
