Topic: winter ressurection ver2.3 (Read 8780 times) previous topic - next topic
I do like those Cossie outlets.
port matched the turbine inlet and cleaned up the outlet port tonight. also smoothed the transition into the wastegate opening a lil bit.
then more exhaust pipe work
almost ready to call that junction good, then i gotta finish my driveshaft project so i can get the rest of the exhaust fitted up.
Looking great Gumby. Now, is that the WBO2 bung on the bottom of the downpipe, or am I seeing things?
on the bottom of the DP is the jack that was holding it in place for the mock up :hick:
welded up that joint, and moved onto my driveshaft project. needed to get it semi-completed so i could install it for fitting the rest of the exhaust thru the tunnel.
i grabbed an aluminum shaft at the junkyard a while back. it was laying out in the middle of a row...someone had robbed the pinion yoke from it. it looked straight and i didnt hafta lay on the cold wet ground to pull it myself, so i bought it. best i can tell, it came from a crown vic. it has the proper ujoints to match my tbird, and had a 4r70w slip yoke on the front.
the stock shaft weighs 14lbs. after cuttin about 8" off this vic shaft, it weighs 8.4lbs!
ever wonder whats inside an aluminum d/s?? a cardboard tube!
i also need to find a T5/AOD slip yoke w/o this stupid balancer. this thing weighs 9.6lbs compared to 3.6lbs for the 4r70w yoke
new shaft installed(for now). i will find a new yoke, and install some fresh ujoints before this new shaft is done.
with that outta the way, i could move forward with more exhaust piping. here is the system so far, all welded up. there is a slip joint after the first ler to make installation/removal easier.
and in the car
money shot down the tunnel, oh the joys of IRS w/a fixed driveline angle!
still gotta add in my flex coupler, and finish the side exit.
gumby,
two things.
1) that first pic sort of looks like the aluminum shaft is floating above the floor and the (cast iron) stock one is it's shadow.
2) what is that thing at the bottom of the downpipe?
__________________
Twin '85 TCs
White/ Grey 2-tone
Quote from: t3skidoo;309505
its a bottle jack!
you can see it in the very lower left corner of this picture as well
What header is that?
tbirdregistry.com
26480
27373
Looks Awsome
Aha, a jack!
What does the car sound like with the ler (love it, btw).  I'd like to do something similar with mine (save weight) but the pipe has to exit after the rear wheels.
__________________
Twin '85 TCs
White/ Grey 2-tone
the header is one of Rod's.
i fired the car before i took everything apart with an open pipe, and empty turbine housing. i slipped two of these lers on the pipe, but its kinda hard to say what the lers will sound like behind a spinning turbo...the sound was still very open pipeish, but less harsh. gonna be loud i think. definitely alot lighter than the big dynomax i was runnin, though.
im trying to get away from a pipe under the IRS diff. adds too much heat. wrapping it would help, but a cooler is an expensive addition!
Quote from: t3skidoo;309552
(love it, btw)
Quote from: 5.8fastcat;309546
Looks Awsome
thanks, guys!
whacked the lower coolant passage off the bottom of my intake manifold.
gonna weld a plate in the opening, and mount the probe for my mechanical water temp gauge in it. relocated the factory ECT to the original gauge sender port in the block
Gumby, just saw your post on TF about the flex pipe.  I'm pretty sure you chose the right position, that's about where I was planning on putting one.
How about posting some audio of the exhaust?  I want to hear how that ler sounds.
__________________
Twin '85 TCs
White/ Grey 2-tone
__________________
Twin '85 TCs
White/ Grey 2-tone
Quote from: gumby;309663
I did this to mine as well.  My coolant sensor for the MegaSquirt is located there.
The exhaust looks good.  I'll have to give it a listen here soon.
here is the flex coupler added in.
Quote from: t3skidoo;309786
Quote from: Chuck W;309792
oh the peer pressure! ;) i need to get it back running before anyone gets to hear it; including me :punchballs:
that means gettin my intake manifold done....
and here i was thinking i had an original, cool ass idea....i guess it must at least be cool if you already did it:rollin:
got any pics?
my plan is to square up the walls of the port in the manifold and fit a ¾" thick piece of aluminum, welded from the backside. i figure if i weld it on the backside i wont hafta worry as much about the gasket mating surface. the aluminum block will have a port drilled and tapped for the temp probe, which should stick right thru into the coolant flow of head itself.
