Topic: '92 Bronco Project (Read 6182 times) previous topic - next topic
'92 Bronco Project
it's a 4wd Eddie Bauer. pretty clean inside and out, except it was a flood car from Ike. 351w is locked up. only paid $300 for it, so i figured i would get it running and sell it, or i may just keep it. depends how much money ill put into it. also has a CLEAN blue title. guess nothing was reported to the Ins company.
starting the teardown:
spent a couple of hours to get it this far. tomorrow the motor will be out so I can inspect the cylinders. I tried again today to turn the motor over with a breaker bar with a long piece of rollbar tubing, but no dice.
1979 Ford Fairmont
[/B]
'92 Bronco Project
and its amazing that it takes 2 hours of labor, before you see the actual motor. LOL!
1979 Ford Fairmont
[/B]
'92 Bronco Project
HOLY !!! 300 bucks!! Ill trade you my durango for it! I dont like  dodges!
'92 Bronco Project
With it being a flood vehicle, once you get it running you might want to think about pulling up the carpet to make sure it's dry under there. The body looks great on it, I'd have to get it running and keep it.
'92 Bronco Project
Nice!
Blows away my 93 xlt before I dogged it out.
Bronco's are  beasts:evilgrin: :evilgrin:
Does it have the E40D?
'92 Bronco Project
Not bad, for 300 bucks, you can't go wrong. Good market for some parts if you decide to tear it apart.
Makes me wonder if someone just got the water out of the cylinders, but didn't change the oil, and ruined the bearings in the bottom...?
I second pulling the carpet up, and was the eec under the water level? (driver's side kick panel)
Should be the E4OD tranny...
, I'd love to find something like that to fix up...I alsways did have a soft spot for Broncos...
'92 Bronco Project
the guy I got it from drained and refilled all the fluids. he pulled the spark plugs and turned it over. it blew a little water out, but then he never put the plugs back in and it sat that way for over a year. I think if he had put the  plugs back in the motor may have still spun over today. oh well. the carpet and interior is dry. I haven't really inspected anything but the motor. I don't even know if the trans is good. (it is an E4OD) I won't worry about other things until I get a good motor in it first. all the lights work, ac fan motor comes on, fuel pump primes when you turn the key, and the starter engages(but won't rotate the motor obviously). it's also new, along with the battery. it was too good of a deal to pass up even if I have to replace the wiring harness, motor, trans and whatever else. I know these things sell for around $3,000 in good running condition.
1979 Ford Fairmont
[/B]
'92 Bronco Project
I had a nice 89 that had the 302 a few years back. I loved the way it rode. I bought it off an old man for $800, and it was like new. I had a low paying job at the time, and it only got like 9mpg, so I sold it, heh. But I still have a soft spot for them. Especially when I see a nice rust-free one. Always check the tailgates for rust at the bottom. The window seals go bad and the door collects water.
CoogarXR : 1985 Cougar XR-7
'92 Bronco Project
I wish you were closer Id honestly trade straight up for it in that shape.
'92 Bronco Project
im honestly not interested in a Dodge unless it has a cummins in it.
1979 Ford Fairmont
[/B]
'92 Bronco Project
hahaha that it does not, but I got it for 300, but it was totaled. I finally took all the advice you guys gave me, let it sink in, took my time and did everything the right way to first time with all new parts, and in the end its a nice SUV, but the 5.9 is gonna get me in trouble haha
'92 Bronco Project
Are you soaking the cylinders with PB Blaster, or even better SeaFoam Deep Creep? I get the stuff at NAPA, a little pricey at $9 a bottle but it's pretty potent.
'92 Bronco Project
i sprayed some WD40 through the spark plug holes the other day, but it wouldnt have helped. got the motor out tonight, and 2 cylinders are filled with what looks like sand and whatever else the water had in it. the other 6 cylinders look fine. all the valves are rusty looking, so ill probably find another set of good E7's to put back on. since the motor was locked up, we couldnt get the converter off. ill try to get the motor loose tomorrow, so i can get it off. i have a lead on another 351w shortblock for $200, so i may go check it out. it was an absolute PAIN to get that mofookie out tonight....
1979 Ford Fairmont
[/B]
'92 Bronco Project
Haha wow cool. Still clearly made a lot of progress though, I'd have been trying to avoid pulling the motor. :rollin: Sounds like you've got the resources you need to get it all set in no time, even if it means swapping the engine entirely.
'92 Bronco Project
I  have always loved the OJ'S...lol is what we call that model bronco in dc.
OJ = OJ Simpson.....lol
86 TC.......Intake, fmic ,bov ,pillar gauges......more to come
