Topic: bolt on pipes (Read 6873 times) previous topic - next topic
bolt on pipes
Reply #45
Quote from: vinnietbird;302417
I have (Stang parts) BBK shorty headers,Pypes off road X-Pipe,lengthened mid pipes (it's a must,our cars are longer in the middle),40 series Flowmasters,and mandrel bent 2 1/2 inch Stang tail pipes (also lengthened,our cars are longer out back as well).All easy to install,and the lengthening of the pipes is simple work to any quality ler shop.
Hey Vin, I am pretty sure on my exhaust the only thing I lengthened was the tailpipes.  Not sure what was different?
I have BBK shorty headers, BBK off road H-pipe, Pypes Violator lers, and Pypes tailpipes.  Its pretty loud. I bolted everything up, hung it with some old coat hangers to get to the exhaust shop and then had them lengthen the tailpipes.
http://www.youtube.com/watch?v=634xO0I9UIA
http://www.youtube.com/watch?v=SvZykdIe2CI
http://www.youtube.com/watch?v=DwfpiQozOlI
bolt on pipes
Reply #46
My midpipes (my first ones) were from a Stang and too short.My second set,that I have now,were custom fabbed and have the ball and socket connectors and are juuuuust right.
bolt on pipes
Reply #47
would there be any significant loss or gain in the matter of either getting an X pipe then the SLP lers .  vs just getting the SLP brand set up with everything?
any benefit in th eheaders as to if they're long tubes or shorty's
Thanks alot for all the help and advice guys. and thanks for baring with me.
bolt on pipes
Reply #48
well you stated you wanted sound not really performance so I set you up witht he parts to get a ok performing, great sounding system. I mean if you want to go all out, thats a different story, and I owuld choose different lers. SLP's are VERY obnoxious on a catless car. I mean I have a local guy with a kit on hsi 02 gt and I can hear him round 2- 1 1/2 miles away when hes getting on it...
bolt on pipes
Reply #49
Check out the coolcats.net write up on the duel exhaust conversion on there. Think about what you actually want out of the car and watch youtube clips of mustangs to get the sound you want. You might bet better off with a $20 cherry bomb and some exhaust clamps then the hundreds you might spend on exhaust work.
If you are going to buy a whole system, get one for a LX mustang. Buy a kit that is all bolt together and hang it all under the car. If it needs lengthened, you can do that in the autozone parking lot, or go to a shop and have them finish it off.
bolt on pipes
Reply #50
i have a quick question, will the stock catted h pipe from a stang bolt up to my bbk shortys and clear my aod column shift linkage
88 5.0 tbird, bbk shorties, new aod, short ram intake, msd ignition, soon to be full H.O.
bolt on pipes
Reply #51
You may need to adjust the positioning of the linkage where it bolts to the frame.
bolt on pipes
Reply #52
ok well i jut went and bought a flow tech offroad hpipe, and everythig looks like it will do jus fine, but what is the air tube on the passenger side pipe near the crossover
