Topic: vibration (Read 1292 times) previous topic - next topic
vibration
I have 87 ford mustang 4 banger 5sp with bad vibration. we have narroed to the tranny or rear end it has a remand trany and 300xxx on rear end but you can feel the vibration through the shifter and back shakes horribly need it fixed any answer will help
1978 Ford Thunderbird Town Landau.
351 mod... not for long :beatyoass:
vibration
Explain the vibration.  WHat RPM and MPH does it occur at?  Does it vibrate when sitting still and in neutral?
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
vibration
35 mph and up any gear and neutral shake when rolling and when motor is off at 35 and up
vibration
I call out of balance driveshaft! Or, a bent axle. Mine doesn't shake until about 80, I suspect the transmission/torque converter of not liking that RPM.
vibration
Wheel balance, bent wheel, bent axle, out of balance or bent drive shaft. Those are the usual cause of vibration.
It doesn't vibrate when you rev it sitting in park does it? If so then you have an engine issue.
