Topic: what prop. valve (Read 1619 times) previous topic - next topic
what prop. valve
Which proportioning valve have you guys used and had good luck with?  Swapping to a TC 8.8 disc rear.
http://www.summitracing.com/parts/BAE-2000035/?image=large
http://www.summitracing.com/parts/FMS-M-2328-C/
What about these 2 ?
I guess this is the plug for the stock PV?  http://www.summitracing.com/parts/FMS-M-2450-A/
One more question.... where do you guys install the adj PV?  Can it be put by the passenger side hood hinge area like the mustangs?
Mike
what prop. valve
I have the second one on mine. You may want to try it without it. I know of 2 cars that didn't use it without issue. On mine I have it adjusted almost all the way out.
