Topic: 83 Tbird rides like a rock? And other fun stuff (Read 3328 times) previous topic - next topic
I have finally had enough of the stiff suspension in the bird. The previous owner put it there, and it was great for years when I wanted a race car, but know I'm starting to feel like it's going to shake the car apart because it's TOO stiff.
I have blue coil springs(No clue what they are if they aren't FRPP) and the shocks are supposed to be KYB up front and Monroe Sensa-Trac in the rear. Need something softer!~  Any suggestions are appreciated.
Also, deleted the 20Lb HR980 Pancake AC compressor today when I upgraded the motor accessories. That was 8 hours worth of fun.
Sooo tired!
Any chassis stiffening on the car?  You'd be amazed at what allowing the suspension to actually work instead of the chassis flexing can do for ride and feel.
KYBs can be a bit rough though, too.
Stiffening such as Subframe connectors? I think those are a little too involved for me, but it does seem like the chassis is creaking/flexing an awful lot when I hit bumps. I'm definitely considering getting rid of the KYB's for sure, I just don't know what to go with to replace them. The factory ones are pretty soft aren't they?
ANY suspension that is on the car will work better with a stiffer platform.
Quote from: Chuck W;300123
i agree!
my 86 drag car stang has over the  last two years got rougher and rougher to ride in. it to the point, that I don't want to drive it. when I built the car in 2001 to 2003. it rode great on the street.
 last week while driving, I some how watch the door flex up and down at the latch side about 2 inch's. thinking that not good. I had to see why. well I have rust at every factory seem, to the point it causing the the body to flex.
remember it easier to fix them, than to find them after they been crushed.
V6 = juvenile delinquency!
I replaced everything in the suspension and it rides great. Turns out 22 years and 130,000 miles kinda wears out the stock bushings.
Well, I have receipts from the previous owner for a full poly bushing set and the shocks....
I guess I should plan on SFC's then. So you guys don't think softer springs would help?
Hard to tell what springs those are.  They could be very stiff.
I imagine doing some MOOG stock replacement springs and getting stock type struts and shocks would help alot, like monroe sensa tracs etc.
I had kyb on my mustang with ford b lowering springs and it rode pretty stiff.
Mike
If you have poly bushings in the front control arms and you have delicate sensibilities, you will be unhappy.
Poly front control arm bushings are probably one of the biggest detractors from ride quality in a Fox car.
:hick: So I figured out what my creak was.. I have the back end apart for a new rearend and I undid the control arms...."Creeeaaaak"! The combined groaning of the rear arm bushings makes one hell of a racket!
So...Next time the money tree comes around, poly bushings for me!
I have no idea what I'll end up doing for the front, I will breach that wall when I get to the front brakes.
I did pick up some poly coil spring isolators, as mine were trashed, and I gotta tell ya, those feel very slippery.
Chuck - I'll have to go through my receipts and see what exactly the previous owner bought, although I don't recall(It's been a week) having any issues with the front end, which delicate sensibilities are you thinking of?
Quote from: jrad235;301813
Just referring to the fact that you will feel just about everything in the road that you drive over with poly front CA bushings.
Quote from: Chuck W;300176
Chuck, I believe you, but shouldnt that be dampend out by your spring and shock/strut choice?? :confused:
Mike
If my chain of thought is correct, since the wheel is attached to the spindle, then directly to the control arm, and from there through the bushings to the K-member, and thus bolted directly to the chassis, the stiffer the bushing, the more NVH that gets transmitted to the driver. The spring/strut combo only effects the ride height/body roll and some bump absorption for the chassis.
Quote from: mcb82gt;321834
Quote from: jrad235;321837
jrad has got it.
The bushing isolates the chassis from road "noise".  Poly bushings negate that isolation.
OK, makes sense, thank you.
Are the polygraphite bushings just as bad as the polyeurethane, in harshness?  Just less squeaks?
Mike
