Topic: changing wheels (Read 1662 times) previous topic - next topic
changing wheels
This winter I want to change it up and get away from the 17x9 Cobra R's.  I want to go to a 17x8 chrome wheel.
I'm torn between two wheels:
1.) swapping to 5 lug and get some chrome Bullitts
2.) keep it 4 lug and go with some chrome '93 Cobra wheels
What do you guys think would look best on my car?
changing wheels
93 Cobra's
20006 Ford Fusion SE
changing wheels
93 Cobra's
changing wheels
Quote from: Blck85TBirdV8;299944
93 Cobra's
Yeah the reason I like those is that they kinda go with the era of the car a little better.  It needs to retain a little of its 1980's-ness.  I miss my original 14" 8-hole wheels...it would be a dream come true if somebody made a replica in a 17x8 or even 16x8!!
Who else has an opinion on this?
changing wheels
5 lug
Think about the future. Change your mind years down the road, or whatever 5 lug is cheap and easier to find
changing wheels
Quote from: DVP;299947
5 lug
Point taken.  The only problem with 5 lug is the expense of changing it over the right way...I am thinking of having everything (axles and rotors) re-drilled, though.  Are there any opinions on this?
changing wheels
Quote from: 50tbrd88;299951
It can actually be done fairly cheap if you shop around. Just read over on CoolCats and make a list of what you want and need and start piecing it together.
changing wheels
I'm really leaning towards the Bullitts...
The car has basically brand new rotors front and rear...so if I go 5 lug, those beotches are gettin redrilled for sure.  So if I'm drilling everything else, might as well do the axles too.  There is a very good local machine shop that would probably do this for me for cheap.
Does anyone know if there are any issues with the Bullitt wheel and a stock fox body 11" rotor?  I think I read somewhere that the center cap won't fit?  Any truth to this?
changing wheels
'93 Cobra, but that's what I was going to go with until I got the Snowflakes.
changing wheels
center cap is an issue with mark7 5-lug setups.
changing wheels
The more research I do, the more it looks like I won't be able to use my fox mustang brake setup with bullitts.  I think you have to change to SN95 brakes....it.
changing wheels
93 cobras or 5 lug swap and GT500s.
got GT500s on my cougar and cobra rs on my t-bird but i did test fit the gt500s on the t-bird looks sick.
