Topic: heater control update (Read 2325 times) previous topic - next topic
i see mention of a swap to rotary type heater controls.  i did a search but my unskilled computer self didnt find anything.  can someone direct me to a post for this?
Thanks,
Mike
Here you go  http://www.coolcats.net/modifying/heaterpanel.html
THANKS!  PDF file downloaded and saved!
Mike
Take a look at my Restoration thread as well... I got it done!
I did it as well.  Very much like the conversion.  Used a rear defrost switch from an Escort and reloacted it to by the light switch.  I'll take some photos tonight and post up.  Wasn't too hard...finding a decent set of s to match the green interior lights was the most difficult.
'87 Cougar LS V6 (stock) Daily Driver
'06 Lincoln LS V8
'12 F-150 SCrew FX4 5.0L
'80 Thunderbird V8 (mild 304) [sold to friend]
HVAC Mod
Here's what my mod looks like:
'06 Lincoln LS V8
why two stereo's?
I think the bottom one is an equalizer.
Signal processor....
It's a signal processor, but I use it mainly just as a 15 band (? - don't recall the exact number of adjustable frequencies) EQ.  It can do a lot more, but I just have 6.5" components up front and 6x9s in the rear, so no sub to work with.  Essentially, my head unit would not need to have an amp, since I have the EQ sending the RCA signal to the amp in the trunk.  But, my system isn't all that special, so I wasn't about to spend a lot of $$$ on a really nice "control unit" head unit only.
'06 Lincoln LS V8
