Topic: Walbro fuel pump (Read 4049 times) previous topic - next topic
Walbro fuel pump
Yesterday I dropped the tank in my T-bird and installed a Walbro 190 lph fuel pump.  I had still been running a stock style (and weak) pump after doing the HO swap in the spring.
The car had been surging at highway speeds and sometimes when you went WOT it would be sluggish and then come in all at once.  Let me just say that with the new pump it is like a new car!  I can't believe how fast and responsive it feels for just being basically a stock HO with exhaust upgrades.  :burnout: (kicked it sideways with white smoke)
I highly recommend doing the pump when doing the HO swap!  That is all...lol.
Walbro fuel pump
Yeah, I got a 255'er to put in my tank before very much longer. Probably do it when I pull the rear out in the next few days.
Walbro fuel pump
My walbro 190 should arrive today.  Cant wait.
Mike
Walbro fuel pump
Walbro 155 here runs great
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
Walbro fuel pump
Had some trouble with a walbro in the silver tc.  Ran fine but would squeel and lock up intermittently so I installed another stock pump.  Will be installing a 255 walbro in thunderstruck shortly
Walbro fuel pump
Does it fit in the stock fuel pump housing, etc? Or is there some modification or a kit necessary?
Walbro fuel pump
I put a 110lph pump ordered for a 87 mustang in my old thunderbird. It dropped in place. It was slightly smaller, but it came with a rubber piece and hose clamp like fittings to hold it in place.
Walbro fuel pump
I run 2 255 pumps in all my performance cars.
Walbro fuel pump
Quote from: TOM Renzo;441749
You show off...........
I can only afford one.
Mike
Walbro fuel pump
I've still got my 255 pound/hour Walbro. Just put it in the Mustang tank earlier tonight, actually. Ran out of kerosene for my heater, called it a night.
I need to knuckle down, install some insulation, and build a wood stove from a couple of barrels..or do something like Thunderchicken posted a year or so ago...make a waste oil burner out of a brake drum and rotor to heat my shop. Something that spreads the heat, instead of having a narrow "beam" of heat that you get from a "reddy" heater....
