Topic: finally did it (Read 5808 times) previous topic - next topic
finally did it
Quote from: ZondaC12;300024
If your engine bay wasnt so friggin' clean I'd bust your balls for not puttin a kit in it. :rollin: :beatyoass:
Maybe I should have spent money on the AOD instead of stuff to clean the engine bay every other week:rollin:
finally did it
I just changed my trans fluid yesterday.  Stuck with the Dex/Merc.  Only holds 11 quarts with the new converter -- even with the cooler.  Changed it out about a year and a half ago.  It got sooty rather quickly.  The  filter had surface rust on it too. :mad:
VERY glad I changed it....
finally did it
How the hell was the filter rusty??? You think you had moisture in your fluid or something?
finally did it
Quote from: ZondaC12;300181
+1.
I changed the fluid in my AOD this year for the first time in 4 years and the filter wasn't rusty. I drive the car maybe 1,000 miles a year if that much.
finally did it
I haven't a clue.  Perhaps from sitting so long with things apart this past spring....
finally did it
That had to do it. If the trans is closed up no moisture should get in.
finally did it
The type f is great if changed regularly.  I was more referring to using the wrong dex/merc usually in combination with improperly set TV/not upgrading the TV retainer on the TB.
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
finally did it
Wow... C4 and 3.73's.  What's that 3500 rpms at 60?  My car irritates me with 4.10's and an AOD, can't imagine no OD, but if you don't cruise at long distances then I guess it's not bad.
finally did it
With 3.73s, P225/55/16 tires, and an AOD I *think* I'm turning about 2800 rpms at 70 mph. I *think* because I forget;)
finally did it
Reply #39
Wow all this auto trans talk has got my head spinning.  Gues I got to relearn all this stuff, due to both mark vii's having auto's.  Makes me want to go give the old AODs a little pep talk!
finally did it
Reply #40
Quote from: thunderjet302;300195
You should definitely be at more like 80 with 2800 rpms. Now...of course it's tough because with our digi-dashes it could be +/- 200 rpms off what you actually think it is. :hick:  But I do know its at that fourth bar and not jumping either direction at 80. Not too bad 3.73s with the OD is still decent for the highway.
finally did it
Reply #41
3.45'swith a 27" tall tire here.  70 MPH is right around 2000 RPM.  3.73's would make it about 2200.....
80 should be around 2500 with 3.73's.......  This is assuming a full lockup converter and the same 27 inch tall tires of course.
With 255/55-16's and 3.73's you should turn around 2600 @ 80 and 2300 @ 70....
finally did it
Reply #42
Quote from: V8Demon;300304
That sounds more correct. Give me a break I have't driven the car in 6 weeks:hick:
finally did it
Reply #43
Quote from: thunderjet302;300424
I dont know how it was up there today but down here it was a cruising day. I bet your stored for winter already though.
I think Ima pull my car out of the garage and set it on fire.:flame:
I mean Im "upgrading" everything anyways.....
finally did it
Reply #44
Quote from: 4bangen;300226
www.clickclickracing.com Dude find a time when you're bored got like an hour and change or more to kill, and go to the AOD tech forum, dont even have to join just start reading old threads searching....I learned so much there, pretty awesome. You will get a real feel for how the things work! Great site.
