Topic: finally did it (Read 5341 times) previous topic - next topic
finally did it
i beat the ever living hell out of my car and am not ashamed to admit it. i bought my t-bird to be abused daily...
as for OD, i'm thinking about just swapping the 260/c4 into the bird to make it driveable while i finish the stang and making the stang my new DD with a FI 302 and a t5 or MAYBE built AOD
86 Mustang GT
finally did it
Quote from: Dougy_Fresh;299839
This will be good
finally did it
I had a friend in high school who beat on his car like it sounds like you do. We all thought he was and idiot because he was destroying cars with his constant beatings. Keep it up and the trans being destroyed wont be your only prob.
finally did it
I quit beating on my cars when I started to go through motor mounts. I've also blown transmissions and rear ends; I'm feeling like those days are behind me now.
finally did it
I broke my AOD because I didn't do any up-grades to it after the GT40 5.0 went in. It died not from neutral drops or beating on it (I baby the car on the street) but from drag racing at the track. It still works but anything more than 1/2 throttle in 1st or 2nd gear and it slips like crazy. If I had just put some sort of shift kit in and a cooler the AOD would probably still be ok.
finally did it
i have a little thing i live by "when it breaks, upgrade"
trans broke, i'm going c4 for now, TKO when that goes if money allows, if not another c4. rearend breaks, i'm going stang 8.8 with 4.10's and 5 lug. engine goes, i'm going 351w or 460. this car is NOT my only vehicle, i have a daily, the t-bird and mustang are simply play toys
86 Mustang GT
finally did it
Quote from: thunderjet302;299986
If your engine bay wasnt so friggin' clean I'd bust your balls for not puttin a kit in it. :rollin: :beatyoass:
finally did it
I thought you said you were upgrading?  the C4 is a downgrade from an AOD.
finally did it
Quote from: 1WLD BRD;300105
I was thinking the same thing.
finally did it
Must be nice to be able to blow money like that though...
(Although I'll never go this far)
-'88 Tbird 3.8
-2012 Altima 2.5 BASE.
Future: Budget 5.0 300 HP.
finally did it
No hate for the AOD here.  I think the biggest problem with them is that most people use the WRONG tranny fluid for one, and improper TV cable setting.  Im laying down 280RWHP & 307 RWTQ in my 93 stang LX with an AOD.  Keep in mind this is a naturally aspirated car with a very mild 306 (f-303 cam, flat top with valve relief hyper pistons, Edelbrok 5.0 heads 202/160 valves, 1.7 crane race gold RR's, cobra intake and a bigger MAF and T-body)  These are not particularly stellar numbers by far but for basically a bolt on engine im pretty happy with the 280 HP with the AOD.  Not to mention i can cruise the highway in the car and still get 20 MPG or so.
Just my .02
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
finally did it
THIS
traction is what it took
And FWIW -- Take the spider gears out of the equation when it comes to the 7.5 (read: install a locker) and they hold up VERY well....
finally did it
Quote from: jandmmustangs;300113
N I think the biggest problem with them is that most people use the WRONG tranny fluid for one,
:rollin:
Wrong fluid, ya gotta be kidding... My AOD ain't seen anything but "F" for the last 10 years(Oct '99) and it has about 750-800 drag strip passes, a few with nitrous(I do change it every spring though)... Yeah it's getting a bit tired, but with the Trans-Go shift kit still is far firmer than any stock AOD...
finally did it
how is a c4 a downgrade? for what i do with the car, it's perfect. this car is not a cruiser, it's a weekend play toy, i have no use for OD
lower first gear, get off the line a little quicker. stouter built, stock for stock. cheaper to build.
86 Mustang GT
finally did it
Yeah the C4 has a 2.46 1st ratio and the the AOD a 2.40, big difference...
Main advantage of a C4 is it's a bit lighter...
