Topic: 8.8 Swap, Control arms? (Read 1961 times) previous topic - next topic
Pulled an 8.8 from an 88 xr7 in the yard.  Do I need the upper/lower control arms or will the ones from the 7.5 fit?
PS.  That thing is heavy.
Thanks,
-Z
The lowers and uppers will work fine.  If you wanna get creative, Fox body mustang aftermarket lower control arms are a direct bolt in.  However, the stang uppers do NOT work on a cougar unless you get an adjustable length upper control arm.  Hope this helps.
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
CHE engineering makes adjustable uppers as well as some other goodies in the proper lengths for our cars.....
http://www.cheperformance.com/cartgenie/prodList.asp?scat=30
I have the non-adjustable upper and lowers.  GREAT product!
CHE on a 8.8
on a 7.5
I like them myself
Quote from: jandmmustangs;299673
The stang lowers are a bolt in but will move the rear end 1" closer to the front of the wheel well opening as they are shorter.
Not really the best idea.
If my 7.5s work, then I'll use those.  I was just happy to get an 8.8 w/ quad shocks and a posi from a cougar so I can just bolt it in.
Thanks.
I have CHE's on the way as we speak.WOO-HOO !!! I've wanted some for a looooong time.
Seems like you could build a jig using the stock stamped ones and weld up a pair pretty easy.
Do they make a noticeable difference in traction?
Quote from: 88CougarGT;299776
If one could do that,and charge $125.00 a set,they would sell great.
planning on it, uppers and lowers. might make the uppers adjustable
86 Mustang GT
