Topic: Rear disc setup...... (Read 1068 times) previous topic - next topic
I just picked up my TC rear,and will not be using the discs.The calipers look good,the brakes look likely were installed not long before the car died,and one rotor is great,one is good,but probably needs to be turned.I also got the parking brake cables.One dust shield is bent.I may try to bend it back.Everything seems to be in tact and I'll be pulling the parts this weekend more than likely.............$100.00 shipped.--------PENDING--------
I also got the following...
-Turbo Coupe door emblems......$20.00 shipped
-"Thunderbird" and "Turbo Coupe" trunk emblems.....$20.00 shipped
-Fuel pump assembly ...in great condition.....$30.00 shipped (pump and all)
-Fuel sending unit assembly...great shape.....$25.00 shipped (for buttstuffog gauges).
-VERY nice fuel tank straps and pins....$20.00 plus shipping
-Explorer cam...super great shape......$45.00 shipped
-90 degree oil filter adapter and cooler.....$25.00 shipped
I need some parking brake cables for mine.
Mike
I'm going to try to sell the whole disc setup as a package first.I will have prices later.I have to make some funds for the Sport.
how is the chrome on the trunk emblems? How much? Looking for NIIIICE ones, Pm me
John
Update
Are you including the hub assemblies with the disc package?
What are you calling the "hub" assemblies?The rotors?If so,yes,they are included.
ttt
Updated
No the hub assemblies are what the calipers bolt to. you have to pull the axles to remove them.  Isn't this part of the swap to rear disks?
The disc setup is sold.It was every single fastener,the thick plates that bolt to the differential,calipers,pads,rotors,everything.If it came off of the differential,it was part of the "kit".
