Topic: question about filler neck seal (Read 937 times) previous topic - next topic
Is the seal/gasket ring thing, that goes in the side of the tank, that the filler neck seals with, the same for mustangs and cougars?
Will this piece work for my cougar tank?
http://www.latemodelrestoration.com/item/LRS-9072A :D
Mike
Nobody??
Mike
I would guess yes.  Only because my 86 Bird has a seal for a 82 Cougar installed and it works fine.  If the filler necks are equal in diameter I'm confident that it'll work.
Armed Forces Car Club
Eastern Sierra Chapter, California
WEB:  armedforcescarclub.com
It'll work.
http://www.foxtbirdcougarforums.com/showthread.php?t=15854&highlight=filler
The actual Ford part is :  F4ZZ-9072-DA
It's a wee bit thicker than the stock one.  Fits fine and stops leaks.
Thank you very much guys.
Mike
