Topic: Drive Shaft Loop Question.... (Read 1196 times) previous topic - next topic
I need a driveshaft loop for my 87 XR7....I tried a mustang one, but it didn't fit correctly.  I know I can get a universal but does anyone have one that was made for our cars.
1987 Cougar XR7 308 S/C
Trick Flow Heads/S-Trim/42lb. Inj./Stg. 1 cam/4.10 Detroit Locker,Yukon Axles,T/A Rear End Housing,CHE Upper Control Arms,Chucks Poly motor mounts,
Working A/C -- BBK Shorties/ H-Pipe/ Flowmasters/ Eibach Springs/SSM lift bars/ Max Motorsports subframe connectors/3300 stall convert/ etc....... list keeps going
Lots and Lots of Parts to make you go FAST !!
2008 Mustang GT - - Dark candy Apple Red
Roush Louvers;18" Polished Bullit Rim;3.55 Posi;Hood Scoop;Pypes Exhaust
i have an 86 cougar. i used the lakewood loop and it seemed to fit pretty good. it has a Boss 302 block/331, vortech 14lbs with intercooler, edelbrock r.p.m`s w/2.02/160, compcams blower grind, scat crank and rods, mahle pistons, r.p.m intake,42 lb. inj,Fluidine radiator d&d motorsports k-member/a-arms with coil overs, TKO 600 5spd,Lakewood scattershield, centerforce clutch and flywheel, 8.8 rear w/31 spline axels/eaton posi/373 gears, max motorsport adj. lower control arms max motorsport panhard bar,maximum motorsports caster/camber plates, baer crossdrilled/slotted on all fours, 17/8 frnt-17/10 1/2 315/35/17 rears
