Topic: lower control arms (Read 1633 times) previous topic - next topic
lower control arms
hey guys
i need to do lower control arms on a 1984 v6 cougar. i have never done that kinda suspension work, though i have changed the struts and shocks. im wondering how hard it is to do. also since having to do the lower control arms , what else should i do?  uppers? sway bar, etc coil springs?  i figured since the car is that old and its all original might as well do it all, depending.but i do have to do the control arms, no matter what .
thanks for any advice
eddie
eddie
my rides well some of them work:hick:
1995 towncar in black 246 K non running
1989 continental 110K waiting for a part
1984 cougar head gaskets done almost ready!
Yikes the daily ride ...1998 chevy lumina:hick:
lower control arms
Do you want to upgrade or refurbish to like-new?
__________________
Twin '85 TCs
White/ Grey 2-tone
lower control arms
If it goes anything like my 86, I had to cut the old control arms out as the bolt was frozen to the bushing sleeve in the lowers. The uppers came right out. Other than that its an easy job. I would do either control arms or at least all new bushings including the two for the uppers on the rear end housing. Good Luck!
2015 Ram 3500 MegaCab Diesel
1986 Thunderbird Elan 302 Crate, x303 heads, e cam, 24lb injectors, gt40 intake, WC T-5, TC rear w/ 3.55 gears, CHP control arms,cobra r wheels.
lower control arms
I'd just get a set of control arms for a 87-93 Mustang from FRPP. They have new bushings and ball joints and bolt right in.
lower control arms
thunderjet im assuming we are talking rear suspension mainly because of the "lower control arm" as we have no upper.
lower control arms
I read struts and lower control arms and figured he was talking about the front end :hick:
