Topic: Water pump tick? (Read 1496 times) previous topic - next topic
Water pump tick?
So since it started getting cold here on cold starts my 'Bird has a ticking coming from the waterpump, its not the heads, or anything just water pump. The previous owner replaced it last winter so I don't think its dieing, it stops when the motor warms up or I spray WD-40 on the inside of the pulley.
Any suggestions?
Water pump tick?
Are the pulley bolts tight?
Water pump tick?
Yep. No play whatsoever.
Water pump tick?
Either replace it or buy a case of WD-40...
