Topic: What SN-95 springs did for the Sport.... (Read 5890 times) previous topic - next topic
man vin, that thing turned out beautiful.
louie  :birdsmily:
My famous last words:
What,you haven't seen it?Have you been gone or something?LOL.LOL.
Very nice, Vinnie. Keep up the good work. BTW, nice addition of the Hurst pistol grip handle.
2003 Marauder 300B
1996-97 Cobra wheel straight but weathered (For Sale)
84 TC manual shifter handle no  (For Sale)
BTW, I had a 1988 T-Bird Sport way back when. I found out that it was totalled shortly after trading it in. It still has the ignition switch recall to date.
Special thanx to EricCoolCats for showing me to this site.:bowdown:
vinnie... do you HAVE brakes :-p cant really see them lol looks nice tho
how full was your gas tank? On my car, I lose almost 3 inches in the rear with a full tank, but I'm sure my springs are worn out pretty good. It looks like it really didn't drop too much in the rear, and the front seems more or less perfect for looks at least. Hows the spring rate? is it more bouncy, or less? New springs or used?
They were used springs.The car actually doesn't feel much different at all in the ride quality,but when you take a corner,you can tell a difference.A lot less "lean".The rear sits as it does because the Sport has air shocks right now and I keep the rear up a little so when I load the trunk,it doesn't squat.If I let more air out of the lines,it'll sit another inch lower in the rear.Eventually I'll buy the Mustang shocks I want and install my ChuckW shock mounts.That'll make a difference.Until then,it stays at it is.I can't go lower in the front.I'm really pushing the limits with the Mach 1 spoiler.Any lower and I'll be dragging on everything.
Roy,I'm using the pistol grip because it' comfortable,and I also have a Hurst billet shifter underneath it.
Forgot about your air springs.
If you want to keep air shocks, but end up with more of a "performance" shock, use the Chuck's adapters and run Monroe MA777 shocks. The 777s are made for a Ford van, and thus are valved quite stiffly when used in a car, but have about the same compressed and extended lengths as Mustang shocks. I used to run these in my ASC/McLaren and they worked quite nicely.
Shiny Side Up!
Bill
Quote from: ProTouring442;296578
Shiny Side Up!
Bill
Hmmmmm,I'll remember that.
vin, i just thought about something. it seems like my car sits at the same height as yours does with the mustang springs, could you measure from the ground to the fender lip front and rear? what size are your tires?
86 Mustang GT
Hey Vinnie
What springs were on your car in the first picture?
William
Quote from: Dougy_Fresh;297128
I'll measure when I get home this evening and post the front and rear.My tires and wheels are as follows....
Rear---17x10's with 275 40 17 tires
Front---17x9's with 255 40 17 tires...no spacers,no rub.
Quote from: 88 Blackbird 5.0;297134
Same springs from the SN95 in both pics.
In the first pic, your car sits noticeably higher than in the 2nd pic.  I notice you have different wheels and a different header panel too.
Quote from: vinnietbird;297137
William
my car has 84 mustang gt springs in the front, and i could tell no difference in the ride height or quality with them installed....everything i have read says 79-93 springs give bad ride quality
86 Mustang GT
