Topic: What SN-95 springs did for the Sport.... (Read 6670 times) previous topic - next topic
This is for an example for those who care........
Before......
After....It may be hard to tell,but there is a big difference.Any lower and the Sport wan't be able to get up the driveway.LOL....really.....I actually sometimes miss the height...
Looks great! I still miss the bird on the nose :(
You need to put some bigger rotors on that beast now that you've got the rims to fit over them ;)
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
X2 on bigger brakes.
Just for posterity's sake, what springs did you use? ;)
'99 Mustang springs.
As far as bigger brakes,It'll happen after the engine gets finished.I've got a few parts already for that task,but,it was either do the brakes or the engine......the engine won.
I miss the Bird too,but when I was replacing the header panel after I got the hole in the other one,this one was the only one I found that was available at the time.One day,I MAY swap it out for a Ford piece,but I have an emblem I'm working on for this panel.I just haven't had the time to get it done.
those aftermarket panels have indents on the inside for you to drill out to but the bird on.  they look so blank without it.. :(
I saw the marks you're speaking of,but I didn't like the idea of the bird on the header being raised.I like them recessed up front like Ford did it.I don't know why that I'm like that.
Quote from: vinnietbird;296284
I am with you on that Vinnie! I totally understand!
Oh yeah I have still not seen the interior of yours!
It's nothing too special,Raven and stock mostly,with a few personal mods just for me.I need to take some new pics,but I haven't gotten around to it.I'll try to do that sometime this week.
stock 99 springs? v6 or gt?
86 Mustang GT
The V-6 and V-8 springs are the same.
Looks good Vinnie! I like the two tone seats!
Take it to a sign painter and have it painted on the header panel. It will look really close to the ford emblem, be a one day thing and you can change it slightly to fit your tastes.
I have a real emblem I'm goping to apply once it's done.It's on the back burner til the engine is done.Plus,I am always on the lookout for a Factory Ford replacement header panel.I got this aftermarket one because if I recall,it was like $75.00 shipped.
