Topic: winter storage jacking (Read 1681 times) previous topic - next topic
i was thinking about jacking the rear of the car under the axle with axle stands  as the notches are kinda rusted is that a good idea
I've had jack stands holding up the differential many times,as well as the front suspension.I was always taught,when you jack up a car for storage,don't let the suspension "hang"
i know just a little to release the pressure
X2 on what Vinnie said...when your shocks are extended, and left for a long period, they'll get rust spots on the rams, which, when you drive the car next, will eat up the seals. Happened to a truck I inherited...had to replace the shocks. After I pulled the bad ones off, I saw the little rust spots and pits all over the cylinder part...
Mine sits on it's tires all winter in the garage and I've never had a problem :dunno:
