Topic: Keyless Entry pad part # questions (Read 3056 times) previous topic - next topic
According to Coolcats, the keyless entry pad for 87-88 cars is as follows:
E7SZ-14A626-A
Well and good.
I've been curious as to what other part number keyless pads could be used as suitable substitutes.  I have 2 Lincoln part #'s specifically that I'm curious about....
1 -- E5LB-14A626
2 -- FOLB-14A626
The connectors are the same between the 2 and it appears that the F0 is simply an update of the E5....
Are the pins in the same location?  Anyone know?  Any other possible substitutes out there?
My unit is in working order and lights up as it should, but I'd like to have one handy for when it stops....
Plug it in and check it.Pulling the door panel for us should be a 1 minute job at this point.
Easier said than done.  I have to BUY them first.....I'd like some confirmation that they'll work before I do that ;)
I thought you said you had them.Sorry.I saw an NOS one on Ebay yesterday.Let me see if I can find it.
Check this...yes,it's $50.00,but it's NEW !!!
http://cgi.ebay.com/ebaymotors/NEW-85-92-LINCOLN-MARK-VII-KEYLESS-KEY-LESS-ENTRY-PAD_W0QQitemZ150138974532QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item22f4faf144
so ithis unit will work for our cars
http://cgi.ebay.com/ebaymotors/NEW-8...item22f4faf144
With regard to the eBay auction, I got one a couple of years ago from the exact same seller, excellent quality. Back then the seller specifically advertised with '86-88 Tbird keyless entry keypad', though.
Actually, I have my keypad right in front of me now, it appears the plug is different from the one in the eBay picture
I checked the part number. It has not been replaced by any other number. There are 6 left in KS for $70.32 list.
2003 Marauder 300B
1996-97 Cobra wheel straight but weathered (For Sale)
84 TC manual shifter handle no  (For Sale)
BTW, I had a 1988 T-Bird Sport way back when. I found out that it was totalled shortly after trading it in. It still has the ignition switch recall to date.
Special thanx to EricCoolCats for showing me to this site.:bowdown:
thanx  the bruins  for the info    im this close to buying one  just need technical confirmation
If it helps any, there's a number on my keypad's plug: CK06
I didn't see this one.....
me neighter
one of my friends used i believe a crown vic pad or a explorer one... i know it didnt fit exactly in there, but it was close enough that you cant tell, and all you had to do was file down the hole for it? mayby i'll get him to chime in here. if not, do what we did and go to the junkyard one weekend and tinker with stuff. bring a battery and take the code off the trunk.
Where exactly IS the memory for the code anyway?
I was under the impression if I swapped a unit up to the connector that my preset code would remain the same.
