Topic: a piler (Read 1250 times) previous topic - next topic
a piler
dose any one know where to get an a-piler pod holder. and will a mustang one work?
88 5.0L aod with duel flowmaster and speedo mod
88 5.0L H.O with 5 speed R.I.P
87 3.8L no trans. geting h.o and 5speed (project never ending thunder) started it as of 8-14-10
96 bronco xl 5.0L 5 speed man4x4
:birdsmily:
a piler
94-2000 mustang.
Have one in mine,works mint.
Also you should change the title to A-Pillar.
a piler
dominator, could you take a picture of that?
full pillar or just pod?
86 Mustang GT
a piler
Just the pod. I used a single pod from the 94-00 and it worked near perfectly.
a piler
are you looking for just a single one? If so I have one.
a piler
Quote from: dominator;295131
94-2000 mustang.
Do they work the same on 83-86 as well. I was thinking about the vert, but It's chopped at the top of the window, and I can't really tell if the pillar trim is the same on both my cars. I'm guessing they are. :D
a piler
Should work the same as the 86 had the same interior as the 87-88.
The fact that the pillar is cut on your vert jerry should not matter as only the top portion would be missing.
I currently don't have a pic as the car is put up for the winter but it is a 2 gauge pod.
a piler
i had a pillar with two gauges which came off of a 94-98 mustang it fit perfect on my 84 cougar. the triple gauge pillar off of a 94-98 mustang you have to cut a little bit off the top to fit.
a piler
ok thanks guys. any one know a site that haves them for cheap. i dont know if im going to go with just 1pod or 2pods just yet.
:birdsmily:
a piler
you can get them cheap at oriellys. i think the two pillar is like $35.
