Topic: Low oil level sensor replacement (Read 11402 times) previous topic - next topic
Here is the one I made by gutting/filling with JB-Weld.  No Leaks!
X
:blahblah:
So I can just spin it out with a socket and ratchet after I remove the plug? Cool:D
BTW mine is nice and clean. It just has an oil drip line that runs from the center of the sensor to the bottom of the pan where it drips, which I wipe up every time I see it;)
Yea.  Its just a huge threaded plug.
No doubt you don't want it to leak but AFAIC, the oil level feature is basically useless... If it's close to two quarts low, it will show low oil when the ign switch is first turned on, but will never activate with the engine running...
Mine isn't hooked up, wouldn't work if I did, as the sensor is out of a junk Windstar engine that threw a rod... The sensor portion was knocked off when the rod went, but it doesn't leak...
BTW danzajax, great pictures!!!
Mine comes on when I'm about 1 quart low.
There is an oil drain plug that just threads in.  I dont have the size in front of me right now.  I have it written down at home.
Mike
mine comes on when i'm 1 quart low. now that i think about it, it was a weekly thing before i put the cam in, now it hasnt come on in a month since i put it in...
wonder if it was leaking around the timeing cover and i just never noticed a spot.....or maybe it quit working and i need to check my oil....i think i'll do that before i leave for work.
86 Mustang GT
I agree with TC.  They seem to vary in sensitivity.  Both engines I have, they leaked pretty bad.  Most cars I've seen in the yard as well.  Seems to me, that they cause the issue they are supposed to detect (low oil).  $0.02
I would have welded mine shut but I no longer have access to a welder.
Quote from: mcb82gt;295621
generic oil drain plug    20mm x 1.50
Mike
Quote from: mcb82gt;295810
Maybe I'll just pick up one of those instead of spending $50 on a new sensor:D
I know this is an old thread but I just wanted to update it. I did an oil change on the T-bird today and replaced the low oil sensor with a 20mm x 1.50 oil drain plug and nylon washer. It threads in fine and has solved the oil leak problem. No more little wet spots under the car in the garage;).
Where did you get yours from?  I went to AZ and O'Reilly's and they both looked at me like I was speaking gibberish.
Quote from: 88CougarGT;313476
I got it from a local, independent, auto parts guy who actually knows auto parts. I told him I needed a a 20mm x 1.50 oil drain plug and he pulled one out of the cabinet he keeps fasteners in. This guy is also great because he sells Motorcraft parts at discount prices:D
1988 Mercury Cougar LS 5 speed-5.0 fuel injected with digital dash
low oil sensor is in the oil pan?  ((WHERE AT)) and how does one stop that  beeping sound that supposedly is a low pressure oil warning??? :dunno:
I have the same leak.  I wastoo scared to pull out the wires as well. It would be great to see the barrel connector picture.
