Topic: Low oil level sensor replacement (Read 11399 times) previous topic - next topic
So I found my little leak. The Low oil level sensor leaks from the area where it plugs into the harness. It leaks enough that if I let the car sit for a week a get a puddle about 3" in diameter (but I only loose maybe about 1/2 a quart over the 6 months I drive the car). So I'm going to replace it when I do an oil change. My question is how the hell do you unplug the wires from it? I've looked at it and can't figure out how it's done:mullet:
The oil pressure sensor, or the low lever sensor? The oil pressure sending unit has a wire that screws on, then there is a peice that unclips so you can then spin off the short wire so you can take the sender off. I thought the low oil level sensor was in the pan?
It is.  It's too cold & wet for me to look at it on mine right now.  I'll take a look when it dries up a bit outside.
Quote from: thunderjet302;295059
Quote from: Haystack;295087
Low oil level sensor. See above;)
Quote from: V8Demon;295089
It would be great if you could. I'm not going to do it till the spring I just want to know how it's on there. I just unscrewed the whole thing with out disconecting it when I did the engine swap because I couldn't figure out how to get the wires off then either. They look like they just slip on but they don't want to pull out....
I had the same problem when I rebuilt my engine.  Both my old and rebuild had leaky level senders.
People say you can buy a plug that fits it, but I couldn't locate one.  So I built my own plug.
 I took it out and disassembled it.  It has a couple of c clips and then the guts come out.
Then I removed the interior piece with a pair of vice grips.
I then cleaned it really good with brake clean and a small brush.
I taped a plastic bag blocking off the inside portion of the bolt.  Then I filled it with JBWeld.
After it was dry I re-installed the sealing ring and torqued it back into the oilpan.  So far, its working great.  I just removed the wire from the harness so it wont contact ground and indicate low oil.
Quote from: thunderjet302;295092
It would appear as if the wire connector unthreads.  Due to my car's newly lowered ride height I can swing my camera underneath, but can't reach without ramps or a jack.  If you need a better pic lemme know.
See my Later posts!  Don't pull it out!  Sorry for the bad advice!
I'd like to see that picture myself.
Quote from: danzajax;295474
The wire just pulls out.
Like the oil pressure sensor?  When I had the motor out, one of the people who helped me did most of the electrical stuff so I honestly don't know and I've never had to mess with that darn wire.
Quote from: V8Demon;295461
The wire just pulls out.  Its a barrel type connector.  Give it a tug, should come right out.  I might be able to get you a picture later tonight.
Well it looks like I just have to pull harder to get it out. I'm hoping a brand new sensor and gasket will fix it. I should have done this when the engine was rebuilt 2 years ago instead of re-using the old sensor :dunce:
Quote from: thunderjet302;295521
Please,there could be kids reading this forum.
Quote from: vinnietbird;295533
Twas the least dirty way I could think of to say it :hick:
On closer inspection, I take back my previous statement about yanking it out.  It appears that it is held in place as some kind of contact.  Mine just popped out easily.
When I gutted mine I recall a couple of circlips holding things in.  Perhaps this is what keeps it in there.
Pic 1 is of the greasy old engine I pulled from the car.
Pic 2 is of the contact (that i folded back over and tucked into itself and tucked into the frame).
X
X
-Dan
Since I was wrong and gave bad advice.  Here is the correct way to dissassemble your leaky-a$$ level sender.
1. Clean it.  Break Clean works awesome.
X
2. Push the rectangular clip up with a flatblade screwdriver and grab it with pliers/another screwdriver.
X
3. Remove the Clip.  It looks like this:
X
(cont.)
4. Remove barrel plug.  Done!
X
Plug looks like this:
X
Socket like this: (you can see this one has been leaking too.  I will try to get a picture of my installed potted one.
X
Now remove it from the pan.  Disassemble it completely, clean with break clean.  And fill it with JB-Weld so it will never leak again.
