Topic: 10 Most Brilliant Products of 2009: Ford Ecoboost V6 (Read 3115 times) previous topic - next topic
http://www.popularmechanics.com/automotive/new_cars/4332412.html?series=88
Ford has built the first of a new breed of turbo engines designed to improve fuel efficiency. In the past, turbocharged engines have been used to boost power rather than save fuel. They ran at efficiency-killing low compression ratios and rich air/fuel ratios to prevent meltdowns. The 365-hp 3.5-liter EcoBoost V6 uses several tricks to overcome these limitations. For instance, the direct fuel-injection system squirts fuel into the combustion chamber instead of the intake ports—this cools the chamber, allowing for a fairly high 10.0:1 compression ratio. The new V6 debuted in the Lincoln MKT and MKS, and the Ford Taurus SHO.
Short article though...
Got to love all of the haters in the comment section.
They're just jealous :burnout: the kind of products that ford is making, will be making will change the game IMMO
