Topic: 88 Cougar 5.0 brakes VS. Mustang 5.0 brakes (Read 1446 times) previous topic - next topic
Real easy like..
Are the front brakes/spindles/hoses on a 88 Cougar LS 5.0 the same used on a Mustang 5.0 of the same vintage?
Thanks
1988 Cougar LS 5.0 (currently parting out):cougarsmily:
1989 Mustang LX Notch 2.3 (Project):ford:
No.The Mustang parts are like the Turbo Coupe...11 inch brakes,ours are 9"..Different spindles,rotors,calipers and soft lines.
we have mustang 4 cylinder spindles, turbo coupes have the gt ones.
Quote from: vinnietbird;294031
No.The Mustang parts are like the Turbo Coupe...11 inch brakes,ours are 10"..Different spindles,rotors,calipers and soft lines.
Fixed it ;)
And to add/amend: there's an adapter fitting you'll need to mate the new 5.0 rubber hoses to the car's stock steel hard lines, but ed if I can recall the size.
Also, you'll have to either get new struts, or shims if you are going to use the ones you have, since there's a difference in spindles.
If you can afford a larger master cylinder at this time you can also switch over to Lincoln/SVO 73mm front calipers. They make a big improvement, cost almost nothing at the parts store, and bolt right up.
pro-five-oh
