Topic: intermittent wiper information please (Read 1552 times) previous topic - next topic
my wipers work in all speeds except intermittent.
i have stumbled across a new wiper motor but dont know if it will work
 where is the intermittent option in the car different from non intermittent wipers  is it all in the motor  or the motor is the same but the circuitry changes i have looked into coolcats but didnt find my answer  thanxs for helping!
I think I remember gaining intermittent wipers with a steering column change. I am fairly sure that it is all in the handle. I really think that the wiring is the same between them, but I'm going back almost 7 years ago, so I would wait for someone who really knows to pop in.
ok haystack  i found a new motor and my intermittent is stinkin
any wiper gurus ?
If you have delay wipers then you have a wiper motor governor under the dash. It's a real mother to get to, but the easiest way is to remove the lower dash panels and drop the column. It's bolted to a metal support plate. Chances are, the governor could be bad. I've had what you've described happen a few times and changing out the governor did the trick. Honestly I don't know if they're available in the aftermarket or not; I used boneyard replacements. But generally, if a wiper switch AND a wiper motor change don't solve the problem, it's pretty much got to be in the governor.
thanx alot eric i apreciate
