Topic: Mustang gas tanK (Read 2162 times) previous topic - next topic
Mustang gas tanK
Will a fox mustang gas tank fit a 88 cougar
'88 cougar 331 supercharged build in progress
'95 Blazer solid axle swapped 4X4- daily driver
Mustang gas tanK
it's a lot smaller, but i have also been wondering about this.
86 Mustang GT
Mustang gas tanK
Completely different shape also.
TED
Mustang gas tanK
Ted is right, Its higher on one side than the other and to be honest I don't think it'd fit. Not to mention the fuel pump bracket is longer than ours is (IIRC).
Mustang gas tanK
I think a Mark VII tank will swap over though.....If you can't find one from another Bird or Cougar.
Mustang gas tanK
My tank has the high right side where the filler neck goes in. Are you talking about another raised spot??
Vinnie, do you know what the capacity is on the MK VII tanks??
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Mustang gas tanK
NO NO NO on the Stang tank, the MK VII is the same at least to '89 or so, probably later... I swapped one onto a '87 TC, except for the sending unit(used orig) tank was exactly the same...
Mustang gas tanK
Too bad your in NY I have a -near brand new gas tank from my old 87 I would give ya.
FOXLESS!!
1994 Lincoln Mark VIII
Mustang gas tanK
Quote from: TurboCoupe50;293687
Like Tom said,same thing as ours.
