Topic: front 5 lug (Read 1345 times) previous topic - next topic
front 5 lug
any objections to converting rotors like what was done to these axles for 5lug?
front 5 lug
EDITED:
Yeah, actually. New Mark VII 5 lug rotors are just easier and probably cheaper than "making" 4 into 5...
If you already have the TC/Stang 5.0 spindles (and 11" brakes) just get rotors for a 94' and up Stang GT. Only I meant Mark VII rotors, not Stang lol. My bad!
front 5 lug
That won't work, Beau. You'd need 94 and up Stang spindles and hubs to use 94 and up Stang brakes. What WILL work is Mark VII rotors.
front 5 lug
reason it wont work is our fox brakes are hub/rotor assy  sn-95 is seperate hub and rotor assy which is GREAT reason to convert to sn-95 components :-D
front 5 lug
Ah jeeze, I had a brainfart...sorry I posted wrong info :hick:
I KNEW there is a rotor that's 5 lug that goes on the Stang/TC spindle lol, just posted the wrong one.
As to the op's question/statement:
I suppose if you had stock 10" brake setup, and were careful to not get the rotor too hot, it could be done.
