Topic: 1991 3.8 mn12 tbird engine swap question (Read 5890 times) previous topic - next topic
I have a 1991 3.8 tbird that has a blown engine and a slipping tranny.  Next, I have a complete 5.0 and T5 that I want to install in said tbird.  How big of a head ache is it to do this swap? Any leads to some good web sites would be very helpful. In the meantime I'll keep on searching, thanks in advance.
~Jason
88 TC with 93 GT 5.0 (.030 over), XE266HR Compcam, SVO 1.6 Roller Rockers, BBK underdrives, BBK 1 5/8" headers, 2 1/2" exhuast with Americian Thunder Flowmaster lers. Tremec 5 speed and 3.73's and alot of other goodies to list.....
Shouldnt be too much harder than a Fox swap since 5.0 was an option in the MN12.
But why a rot box?
Rot box? hahahaha....is that a term for a mn12? If it is, well there is no rust on this one, plus it was donated to me.
Texas.... Lucky
The 5.0 for the MN12 uses a lower intake manifold like the 94-95 Mustang GT.
2003 Marauder 300B
1996-97 Cobra wheel straight but weathered (For Sale)
84 TC manual shifter handle no  (For Sale)
BTW, I had a 1988 T-Bird Sport way back when. I found out that it was totalled shortly after trading it in. It still has the ignition switch recall to date.
Special thanx to EricCoolCats for showing me to this site.:bowdown:
MN-12 uses a shorter upper plenum...a standard HO upper will bolt on and you could make it work with the proper TB adapter available from almost every aftermarket company...however, hood clearance may very well be an issue.
-Don
The T-5 shifter will come up through the floor at the wrong place and there will be clutch cable(slave cyl?) issues to consider... No doubt doable, but you'll be scrounging a bunch of small pieces...
Agreed. You will likely have issues with hood clearance and shifter location. From what I've read, the shifter will want to be somewhere inside the dash underneath the radio.
I don't think a MN12 ever came with a T-5, Did it? The Mazda 5-speed was all they got, the M5R2.
Quote from: jrad235;293297
Might want to check with some supercoupe guys.
ThunderbirdUnderground is a cool bunch of guys.
Correct you are.
Well, after seeing my options, I'm just going to repair what needs fixed on the Tbird. I'll just use that as my daily driver and just find another fox body to donate my drivetrain. Thanks again for the input.
~Jason
Use the motor and an M5R2 get a 164 tooth flywheel.
An intake manifold from a 91-93 Cougar of Tbird should not be too hard to score.
Nah, I'll just keep this one stock. I'm really not a hugh fan of the MN12 body style in the first place. I'll keep my eyes peeled for a fox body to put my 5.0 and T5 in.
Quote from: SR71TC;293483
Good plan.
