Topic: torque box plates (Read 1920 times) previous topic - next topic
torque box plates
i bought a mustang shell this past weekend that came with 2 sets of torque box plates, one set installed and one set still in the box...so i'm wondering if they will fit my t-bird
86 Mustang GT
torque box plates
these kits also have plates for the upper control arms, will these fit?
86 Mustang GT
torque box plates
Quote from: Dougy_Fresh;293156
Tbird/Coug arms are longer than Stang's...
As far as the torque boxes, I can't tell you, but Chuck or gumby would know for sure.
torque box plates
you have to do a little modding on the plates.
they are short, so I had to add an 1 1/2 to it and red-drill the hole.
the uppers, I had to rebend to make fit, and redrill 1 hole for that one.
torque box plates
X 2 on lowers being too short and the need to tweak the uppers.  I had to do a little grinding on the uppers as well as relocate one of the holes.
Damic: nice pics of the install.
torque box plates
LOL
Thank you.
I think I spend more time taking pics, then working on it. :hick:
I think it took about 10 hrs or so to get them modded and installed. A lot longer then I really expected.
should take less time going in knowing what needs to be done
torque box plates
"I think it took about 10 hrs or so to get them modded and installed. A lot longer then I really expected."
LOL.  I was right there with you!  I couldn't believe how much time they sucked up!
I installed a set on my Mustang, it was pretty easy...
torque box plates
Have we seen the T-bird break out like the Mustang?  I did a continuous weld all around mine and for now it looks okay. I will have to keep an eye on it.
Thanks for the pictures.
TED
torque box plates
would i need to do all the welding and redrilling if i just weld them?
86 Mustang GT
torque box plates
you still need to lengthen the lower brackets, and drill a hole for the control arm bolt.
the idea of the bolting is to secure the inner plates to the outer, and sandwich the original floor and supports between them for strength. you can weld everything, but you still need the connection of the inside and outside for it to work properly, or you'll just rip the outer stuff off the car.
