Topic: Red stripe around 87 Turb coupe is dull (Read 2604 times) previous topic - next topic
How would you bring back to life the red stripe around the TC, mine is looking dull.
Try a bit of polishing compound first, but in all likelihood you won't be able to bring it back. My plan is to pick up a roll of high quality 1/2 stripe and cover it.
Shiny Side Up!
Bill
I was going to paint it...but like your idea way better!
1000 grit sandpaper.
i thought someone on here sold that molding
Junkyard Cat
Quote from: 87cougar347;292959
Aerobird used to sell it, but they're not around anymore.
1987 Turbo Coupe - Son's car
1934 Ford - My project car
Quote from: Tbird232ci;292941
That wont ruin it?
Demon-you are the man. Has anybody actually bought the red molding from these people? Please post up some pics if you did and let us know how it was compared to the factory molding.
Thanks
Ken
Quote from: cyber-junkie;293847
That wont ruin it?
I wet sanded with 1000 grit and it worked very well. If it makes you leery, you can use most metal polishes and it works decently.
Quote from: kendoo130;293877
Thanks
Ken
+1
I'd like to know if anyone has actually purchased and installed the red molding too?
Here is the rest of the story,, and no, I decided very recently that the resource does not sell a flat top surface molding.  a easier solution is here..........http://www.foxtbirdcougarforums.com/showthread.php?t=24744
options out there today have a more rounded top edge with widths that may not fit like oem. anyway, enough babble here, read the link above.
red and gold 3m vinal electrical tape examples of mine.
Has anyone tried some 1/2" chrome tape for those of us with chrome moldings?
Quote from: thunderjet302;294064
In my original post , i pointed out some things i discovered about chrome molding.
my gold molding is not gold.  they added a gold paint to the inside of the plastic cover that attaches over top of a chrome covered molding.
the chrome molding guys have a simple adhesive clear cover.  The next time I have to deal with the chrome world, I will remove the clear plastic cover to expose the shiny chrome under there.  Next I would use some high quality clear packing tape and cover the chrome.  that would fix the problem for many more years.
I dont know if you can get chrome tape in anything but aluminum adhesive rolls like at lows in the plumbing section or as in heat tape.  That stuff tends to deform and krinkle when you undo it.
You could add chrome painted electrical tape but peeling off the laminate cover would be better,,,maybe,, dono really since i have not completely removed the clear laminate.
