Topic: how to lower the rear (Read 1929 times) previous topic - next topic
what is the best spring to lower the rear of a 83 thunderbird around 1.5 to 2 in. and is the chart ok to use for the front
I used SN-95 Mustang springs.Right at 2 inches lower,direct swap.I did have an alignment done afterwards,I also swapped the lower a-frames,tie rods,steering rack,and strut mounts.
when you said you swapped a frames,tie rods,steering rack and strut mounts you mean to a sn95 gear
Vinny...were those V6 or V8, hardtop or vert car springs?  I'm not sure there is a difference but just assuming there is.
1988 T-Bird Sport Coupe--5.0 HO, MAF swap, 1-5/8" shorties, BBK/Flowmaster exhaust, Explorer intake, 70mm Edelbrock TB, T5, B&M short throw, Centerforce clutch and PP, disc brake TC rear w/ 3.55's, TC front brakes, '98 Cobra springs, DIY SFC's, other misc .  14.05 @ 98mph with launching too low and shifting too high.
Let the air out of your tires! Seriously, Mach1's and CHE adjustable's will work.
Quote from: 83thunderbird;292887
The a-frames (same as the Bird's) and springs were SN-95,the rest was for a Sport model T-Bird.
Quote from: Dan B.;292908
The V-6 and V-8 are the same.
