Topic: Driveshaft question...... (Read 4942 times) previous topic - next topic
I got a replacement drive shaft at the boneyard and while I was installing the u-joints,that vibration ring (?) on the drive shaft yoke came off.Will that cause any issues with the drive shaft or it's balance?
Hello......anybody out there? I only hear crickets chirping......helloooooooooo...........I feel so alone.
I took mine off
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Apparently I did too,just not on purpose.No issues after it was removed?
just retorque every nut and bolt on your car every week. you should be fine.
1979 Ford Fairmont
[/B]
Had a shop remove mine when they put new u-joints in and balanced the shaft. No problems.
TC#1- 2.5T- 10.14@134....9.76@138 with a 50shot
TC#2- Turbo BBF project
TC#3- parts car
I'm getting a cop car aluminum driveshaft and having it shortened and balanced for the Sport.
how much is that going to cost? not counting the shaft....i too have a too long alum shaft
86 Mustang GT
I picked up an Aluminum Aerostar shaft and I was quoted...I think $60-70 for the balance, and another $60-70 for the shortening, but up here there are only about three shops within a reasonable distance (1-200 miles) that can/will do it.
Quote from: Dougy_Fresh;295429
In Oklahoma City,it'll cost about $85.00 to shorten and balance.
Quote from: jrad235;295432
There was this place in Gresham I was referred to when talking with a good transmission shop - I will have to find their card again. I have no clue on the pricing though. I thought Aerostar shafts were a little too long for Mustangs but too short for Thunderbirds/Cougars?
1988 Thunderbird Sport
what should the length on a t-bird shaft be? AOD/7.5 and c4/8.8 if it would make much of a difference
86 Mustang GT
The aerostar one I have is to short for my t-5 and 8.8. Here a post with some measurements in it.
http://www.foxtbirdcougarforums.com/showthread.php?t=22510
Well, I've got a v6/C-5 with a 7.5" rearend, and my stock shaft measures about 50", and the 1995 Aerostar shaft(Welded, probably out of a 2wd model) measured about 55" or so.
Good to know - I should look for one too then. I've got 1" more to play with than aod's, having a transmission with a 1" longer bellhousing. I really need to get out to some yards/cars soon as I'm bored to death with everything basically working as it should.
