Topic: Confused...do I need a new throttle cable? (Read 2390 times) previous topic - next topic
Okay, so my 88 Cougar (converted to a T-56) is still in pieces (dash out) and I noticed two things: the gas pedal is way lower than the brake/clutch and the throttle cable has about an inch of slack before it does anything. If that inch of slack was gone, the pedal would line up nicely so I can heel-and-toe. The cable is stock, but the car got converted with 91 Mustang pedals.
The cable on my 87 Mustang T5 is TIGHT, so I gotta fix the Cougar before the dash goes back in. I also suspect that slack is why my car feels slower than I last remember...so here's my questions.
1. Can you adjust the cable at the throttle body to remove 1" of slack?
2. Would a throttle cable from a 1988 Turbo Coupe 5-speed interchange?
3. Does anyone sell a new cable?  I saw 5.0 Resto had it, but its $100.
Thanks in advance.
pro-five-oh
I think that's normal. Mine was like that. I put in a throttle cable from an 88 Mustang GT and it was the same as it was with the factory cable (about 1" of free play). To fix it and raise the pedal I just used a 1" nylon spacer between the pedal and the end of the cable. It took out the slack and raised the pedal. Get a spacer that is the same diameter as the green plastic thing on the end of the cable and who's inside diameter is a bit bigger than the cable. Cut a slit in it, slip it over the cable, and use a hose clamp to keep it from opening up an poping off the cable. Put it between the green plastic thing that holds the cable to the pedal and the end of the cable.
I was thinking about that too...except my 87 Mustang has no slack!
Anyway, how long have you had the space on there?  It seems like a good idea that might not last very long.  That's my only concern.
pro-five-oh
Quote from: pro-five-oh;292189
It's nylon.  It'll probably last longer than the cable.
:birdsmily:
UPDATE: I got a barbed fitting (brass, 1/4" inner diameter) from Home Depot, cut it down the middle so the cable can slide through...and then cut it to 1" to take up the slack.  Then I clamped the brass back shut, its not going anywhere. Perfect fix for $5.
Mission Accomplished.  Now to get the dashboard back together so I can actually drive the thing. :hick:
pro-five-oh
Pics please?
Quote from: pro-five-oh;293879
The nylon spacer and hose clamp cost me $1 ;)
