Topic: driver seat (Read 1221 times) previous topic - next topic
driver seat
does the 88 t bird share front seats with any other car???
driver seat
Would this be a sport/tc seat (with floor mounted console) or base model seat (with attached consolette)?
Basically, the front seats interchange with about any 80s ford/mercury (bolt-hole wise). They will all "fit". As far as finding the exact shape and material match, I am not too sure which ones match in that manner.
I know any fox body seat will interchange. You can even swap in a fairmont bench seat if you have no power options to lose by eliminating your console, heh.
Some non-fox seats fit too, like 80's escort seats (escort gt seats are nice), and tempo seats. I heard that sn-95 mustang seats fit too, but I am not too sure.
http://www.coolcats.net/tech/reference/parts.html
CoogarXR : 1985 Cougar XR-7
driver seat
To add to the above post:
Remember that the seat brackets (what holds the seat to the floorpan) are Tbird/Cougar specific...as in, Mustang brackets will NOT work ;) The seats themselves are plug-and-play, so to speak.
driver seat
Quote from: FordTruckFreeek;292148
In other words you can unbolt the seats from the tracks and they will fit on the car specific tracks. You will also notice that at the back of the seat frame bottom there are multiple untapped holes to adapt the seat to the particular seat track that they will be mounted to.
driver seat
so i have to find a t-bird seat track?
driver seat
Quote from: pegasus;292307
To have your seats "bolt in" a T-Bird, then yes. You need to answer some questions too. Is it a driver side or passenger side? Is it power or manual? Power passenger tracks were not standard. They're not super rare or expensive, they just weren't standard. Manual driver tracks aren't particularly expensive either, but they are kind of rare.
1987 Turbo Coupe - Son's car
1934 Ford - My project car
driver seat
I just added a passenger side power seat track from an 85 Fox Lincoln Continental. It required me to drill extra holes in the seat track to line up with the floor bolts at the rear. I had to relocate the mount for the seat belt buckle and the track sits up just a tad higher than the Tbird driver's side seat in it's lowermost position.
I do recommend finding correct Tbird/Cougar tracks if you can find them.
driver seat
Quote from: Watchdevil;292375
Then what did you use for wiring and switches?
driver seat
Quote from: FLSTCI71;292384
I used the wiring and switch connector base from the same Lincoln Continental and spliced them into the 12V supply wire and ground for my driver's side seat. The Continental switches will work, but for them to have matching finishes I got them from another donor car. I changed all my console switches to ones with chrome which were harvested from any 1980's full-sized Crown Vic, Marquis or Town Car. I have it all covered in my Restoration Thread!
