Topic: Oh.My.God.Terrible taste in mods v.5.4 (Read 4086 times) previous topic - next topic
Okay, normally I'm pretty tolerant of other peoples ideas and tastes in what works well for mods... but, this guy gets my vote for "Most Hideous Looking Hood bolted onto a Thunderbird"  award, hands down.
  I give him credit for stuffing a 5.4 under the low hood line of an MN12 but that hood has GOT to go, I dont care if it means the supercharger gets evicted from the engine bay.
  Enjoy  :rollin:
Because you're dyin to know why someone would put that ugly of a hood on...here's the reason for that strange, grotesque looking lump in the hood  :mullet:
Only needs 3 things! hood! different supercharger! new back tires!
Quote from: FordTruckFreeek;291797
I agree. I would've installed a Whipple which is lower in height and made a better hood to cover it or don a factory hood with it protruding through. I've seen a couple of Crown Vics with this setup.
2003 Marauder 300B
1996-97 Cobra wheel straight but weathered (For Sale)
84 TC manual shifter handle no  (For Sale)
BTW, I had a 1988 T-Bird Sport way back when. I found out that it was totalled shortly after trading it in. It still has the ignition switch recall to date.
Special thanx to EricCoolCats for showing me to this site.:bowdown:
I would've  just went with a cowl hood.
20006 Ford Fusion SE
It looks like it has a tumor. :yuck:
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
or a nasty NA 5.4 DOHC.
~John~
It does make a person looking wonder what it is.Kinda cool and different.I really get sick of seeing cowl hoods on everything.Would I use that hood,no.But for what it is,I give 'em credit for using their imagination and the work involved.I can't be one of the negative votes for it.
I think I would have relocated the overflow tank and mounted the blower lower in the engine bay. That "knot" in the hood looks like it was shut down on something...
Raleigh, NC.
The hood looks quite odd, I like the idea of a SC'd 5.4 MN12 Bird but the hood just kills it for me.
Quote from: 04FordHarleyF250;291884
Agreed. You would think after swapping a SC'd 5.4 in there, moving the overflow tank would be no big deal. Especially compared to making a hood like that... :hick:
Wonder what it does to the aerodyamics:hick:
FOXLESS!!
1994 Lincoln Mark VIII
wonder what it would do with bad motor mounts and some power.
Quote from: shame302;291857
good luck on that...  NOBODY has been able to fit a DOHC 5.4 into an MN12 yet.  you have to cut the shock towers just to get it in..  hell a SOHC 5.4  BARELY fits between them...
and yeah that is Butt f**k  UUUUGGGGGLLLLYYYY!!!!  i dont care if it runs 10's, it is still hideous!
i can tell the hood is a bit odd, but are there any more pictures of this car with the hood installed?  as far as cutting a hole in the hood for that SC set up.. i think i recall a civic done up that way?  it may have been a turbo...
Function Over Form. Enough said.
