Topic: v6 owner please help (Read 1667 times) previous topic - next topic
i need to know the length of which spark plug wires go where from the distributor to the engine of a 3.8?
the question running along side a sig like yours makes me have to ask the obvious...
why with so much talent should such a non issue be so urgent?:D
I dont have the lengths memorized, sorry.
I would make the pass side 1-3 approx 2' and the drivers side about 3' ea if your guessing.
Do some cut to fits. They seem intimidating, but it's an easy job. It makes for a much cleaner install.
the reason i needed the lengths were i removed all my wires from the distributor and put a performance distributor. but i am just trying to make sure i put the right length wire in the right spot.
Hmm, the longest to #6, next longest to #3, ........
:birdsmily:
do you have a build thread on that motor? i'm thinking about picking up a 3.8 powered fox mustang for a DD and that motor sounds interesting
86 Mustang GT
no not yet i havent found all the pictures and information on the engine. all i know is its a 4.2 stroker kit with mild port and polish, mac longtube headers and mac underdrive pulleys, some nitrous.
Quote from: blackcougar71;291801
i dont get it,, if your standing right there infront of your motor, just shorten any given wire thats too long.
all you have to do is take one end apart.
you lost me,, sorry
i took all the wires off the distributor cap/ and engine when changing the distributor. now i dont know which length wire goes to which part of the engine. do you understand?
check the firing order...
It has coil packs in the picture, but if you just bring the numbers into the 5.0 one and kill the last two, it will be right.
my car doesnt have a coil pack its a distributer. but i figured it out from some of my old sparks since marked them where they should go.
