Topic: Slipping in 5th (Read 1023 times) previous topic - next topic
Slipping in 5th
I'm driving on the freeway and I go wot in 5th gear and all it does is revup. what could be the possible causes of this?
Thanks
Troy
[SIGPIC][/SIGPIC]1988 Turbo Coupe 19psi ,K&N Cone TurboBack 3in Exhaust , Ported Big Valve Head w/ Bo 1.5 , Stinger short throw
Slipping in 5th
A worn out clutch!
Slipping in 5th
X3, but should be slipping some in the lower gears, if not must be a tranny issue... If it were a gear issue, would no doubt be making some noise...
Slipping in 5th
well it doesn't slip in lower gears. not that I've found anyway. also I barely have to push the clutch down to get it to engage. the car does make some noise while driving on the freeway. it comes from right below the shifter. only in 5th tho.
